Not very exciting but i removed the heated grips today.
2020-06-17_05-55-23 by Steve Weeks, on Flickr
Standard ones fitted. Only £18 for the set, which includes the housing as well as the grips...
At Donny i was having 'feel' issues with them and in a couple of corners they felt really 'fat' as i was shifting and moving, for example on the exit of the chicane, i wanted to change from 4th > 5th and because i was still hanging off while getting onto the straight bit, i was struggling to get a proper grip on the bars to grab clutch for the change, (i know, clutchless changes, but no... i don't do them, don't like them), so went out and got the skinnier standard grips to stick on.
Oh, is that another KTM ? Really ? Are you sure ? Is this the one and only keeper ?
- Has thanked: 5408 times
- Been thanked: 12939 times
- Has thanked: 4288 times
- Been thanked: 2803 times
Re: Oh, is that another KTM ? Really ? Are you sure ? Is this the one and only keeper ?
Did you just glue them on, as assume you had to dremel the tubes again?
The throttle side comes as a whole unit, grip and housing pre built. The clutch side is just a rubber grip.
So clutch side glued on. Throttle side goes into housing.
