New Bike day
Gedge
Has thanked: 170 times
Been thanked: 148 times
New Bike day
Post by Gedge »
After a lot if searching and waiting I finally picked up my new Haibike Hardseven7 this morning ..rode it home from Chichester using a couple of cycle trails and cycle paths., very pleased with the way it rides .
Very comfy ergonomics too.
Only downside for now is that it’s restricted to 15.5 mph and I can’t really alter anything until after first service then it will be put right .
Has thanked: 5450 times
Been thanked: 13085 times
Re: New Bike day
Lol and faceplant.
Congratulations
Re: New Bike day
What spec is it?
Also you can go faster, you just have to pedal a little harder.
Gedge
Re: New Bike day
Post by Gedge »
Le_Fromage_Grande wrote: Thu May 20, 2021 3:56 pm What spec is it?
Yamaha PW ST motor ..Rock Shox 35 Silver. Shimano MT 410 brakes ..
Gedge
Re: New Bike day
Post by Gedge »
Didn’t bother waiting for the first service ...25 miles done and found the restriction just too annoying ...so this morning I fitted a Volspeed derestrictor which allows you to choose any max assist speed you want ...I’ve currently got it at 20 and the difference is night and day ( it also irons out the ‘wall’ when you reach max speed) ..probably stick with it around 20 for a while now while I put some more miles on..
Saga Lout
Has thanked: 565 times
Been thanked: 754 times
Re: New Bike day
Post by Saga Lout »
My eyes!! :shock: :shock:
I know beauty is in the eye of the beholder but they haven't even tried to make it attractive.
Has thanked: 1745 times
Been thanked: 2085 times
Re: New Bike day
Can you get a derestictor kit for a cheaper hub motor. ??
Gedge
Re: New Bike day
Post by Gedge »
Dodgy knees wrote: Fri May 28, 2021 1:52 pm Can you get a derestictor kit for a cheaper hub motor. ??
There are usually ways of derestricting a hub motor that doesn’t require a kit ..often the speed limit is set through 2 wires in the controller that can simply be disconnected ..depends upon the model though ..
