Best Discs
Jazzy
Been thanked: 7 times
Best Discs
Post by Jazzy »
Any idea on the best discs to go for. Bike is a gsxr1000 k7.
Brembo, EBC or other.
I get 25% off EBC through the TRF so they are significantly cheaper than Brembo.
Cheers
Has thanked: 532 times
Been thanked: 7226 times
Re: Best Discs
You want the best or you want the cheapest?
Best upgrade I've ever made to a bike was PFM Ductile Iron Superbike Discs, but that was on an older Fireblade, a half modern GSXR would probably be fine on stainless discs. I put an EBC disc on my Bullet, because they were the only option other than factory fit. I'd never put them on anything that I was going to use in the wet.
So, if I were you, Brembo Series ORO.... but from a reputable supplier as there's a fuck ton of fake Brembo bits out there.
Has thanked: 9682 times
Been thanked: 9702 times
Re: Best Discs
KungFooBob wrote: Wed May 27, 2020 8:03 pm You want the best or you want the cheapest?
Yeah,what he said. I used to like EBC pads,so I bought EBC discs and pads. I'll never do that again.
Has thanked: 1326 times
Been thanked: 1652 times
Re: Best Discs
EBC Prolites.
Are generally to be avoided. Got them on my Slingshot and I can't say I'm a fan.
Has thanked: 10115 times
Been thanked: 6649 times
Re: Best Discs
Hey Fatso :) Why you wanna change ? I had no problems with the brakes on mine. Maybe it's coz you is a few stones heavier than me :)
Jazzy
Re: Best Discs
Post by Jazzy »
Yorick wrote: Wed May 27, 2020 11:22 pm Hey Fatso :) Why you wanna change ? I had no problems with the brakes on mine. Maybe it's coz you is a few stones heavier than me :)
The bobbins have worn out. Plenty of life still in the discs as I am so waif like there’s been no wear :)
I could buy those aftermarket replacement bobbins.
The bike only gets used once or twice a year, I’ve only done 3000 miles in the last 5 years on it.
Not sure I’m up for spending £400-£500 on a set of PFM or Brembo’s.
Set of EBC is £220ish.
There is some other makes, that I’ve not heard of, then theres some used oem and galfers on eBay, but a bit of a risk on 2nd hand discs.
scottyuk
Has thanked: 168 times
Been thanked: 257 times
Re: Best Discs
Post by scottyuk »
I put Brembo Oro's on my K3 1000 track bike. Cheaper than OEM and no worries with warping etc.
www.carpimoto.com were cheapest I could find :thumbup:
Has thanked: 626 times
Been thanked: 4063 times
Re: Best Discs
Replace the bobbins, buy discs from Suzuki or fit expensive race discs, do not fit cheap discs, they're a waste of money, you'd be better off with a 2nd hand set of OE ones.
Re: Best Discs
Julian_Boolean wrote: Fri May 29, 2020 1:26 pm Replace the bobbins, buy discs from Suzuki or fit expensive race discs, do not fit cheap discs, they're a waste of money, you'd be better off with a 2nd hand set of OE ones.
I never knew you could replace them. Are they hard to fit?
https://beringerbrakes.co.uk/product_in ... ucts_id=31
Re: Best Discs
They're easy to fit, getting the old ones out is the tricky bit, needs careful use of an angle grinder
Re: Best Discs
Julian_Boolean wrote: Sat May 30, 2020 6:13 am They're easy to fit, getting the old ones out is the tricky bit, needs careful use of an angle grinder
Just been to look at mine, but they're Brembo. So what holds the bobbins in place? I assumed they were "pressed' into place ???
Jazzy
Re: Best Discs
Post by Jazzy »
Thanks all
Ordered the brembo series oro discs and sc pads in the end
Re: Best Discs
Yorick wrote: Sat May 30, 2020 8:57 am
Original ones are like large rivets, one end is squashed to keep them in, the replacement ones I used had springy washers and circlip to hold them in, this was about 25 years ago though.
Re: Best Discs
Julian_Boolean wrote: Sat May 30, 2020 9:23 am
Aha, just Googled that. Not sure if I'd feel competent to repair discs.
