DIY roller starter
derek badger
Has thanked: 769 times
Been thanked: 1135 times
DIY roller starter
Post by derek badger »
Just picked these up on eBay very cheap. The guy had a local engineering firm make up the parts and then they sat in his shed for years. He's also thrown in some chain and sprockets that he forgot to include in the advert. So the plan is to drive the rollers with either a 9" grinder and remote switch or a small engine with a centrifugal clutch...then use it to start the bastard KX500. The end plates need welding onto the drums and the shafts and I need to knock a frame up to mount it all too.
Has thanked: 7817 times
Been thanked: 2527 times
Re: DIY roller starter
You might be better off with a "tyre" on the roller to grip the tyre on the bike better?
derek badger
Rockburner wrote: Sun Mar 28, 2021 12:52 pm You might be better off with a "tyre" on the roller to grip the tyre on the bike better?
One of them is knurled. I've seen the rollers in metal, polyurethane and rubber coated. Well suck it and see. They seller had planned to use a 24v van starter and connect it direct to his race van, but a crash in an Irish road race changed his plans. Hence the parts being stuck in a shed all these years.
Has thanked: 1346 times
Been thanked: 1722 times
They use them on a few bikes at Barbon hillclimb.
I can't remember if I got any pictures but its the sort of technical thing a saddo like me would have a photo of.
I'll have a ratch.
Was started off a grinder, off a generator. Which does seem kind of longwinded to start a kickstart equipped bike but I've just bought a gold anodised (Yesssss! Ahem) cylinderhead with a decompression button to achieve basically the same thing*.
*To be fair it also has interchangable domes so I can dick about with compression without knackering a head if I go too far.
wheelnut
Has thanked: 907 times
Been thanked: 1001 times
Post by wheelnut »
Next thread will be ‘how do I get a KX sized dent out of my garage door?’ :D ;)
derek badger
demographic wrote: Sun Mar 28, 2021 1:38 pm They use them on a few bikes at Barbon hillclimb.
I'll have a ratch.
The grinder seems the easiest option, I'll start looking on the Facebook marketplace for a 2nd hand 240v 2000w one.
Has thanked: 143 times
Been thanked: 497 times
Post by Silly Car »
wheelnut wrote: Sun Mar 28, 2021 2:52 pm Next thread will be ‘how do I get a KX sized dent out of my garage door?’ :D ;)
derek badger wrote: Sun Mar 28, 2021 2:53 pm
Sorted :thumbup:
derek badger
Silly Car wrote: Sun Mar 28, 2021 3:19 pm
Sorted :thumbup:
Yes, hence the front brake bracket becoming the main priority at present.
derek badger
Two large packages arrived yesterday...
Fookin' hell they've been properly engineered. Heavy and well made rollers and shafts.
Steel for the frame should be here next week, I've checked the MIG set and I've got gas and 0.6mm wire so I should be able to make a start. Just need to find a suitable power plant for it and look at the drive train.
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
Just use the kick start to move the piston to the right point on the upstoke and gan it a proper kick.
derek badger
Asian Boss wrote: Fri Apr 02, 2021 3:59 pm Just use the kick start to move the piston to the right point on the upstoke and gan it a proper kick.
You can pop over any time you want and have a crack at in your Airmaxs mate. It not kicking it that's a problem, it's cranking it for a longer duration that's killing me.
Asian Boss
derek badger wrote: Fri Apr 02, 2021 8:01 pm
Haha! :lol:
I remember when I had an RMX250 years ago and I kind of neglected it and it was a pig to start and even kicked back once or twice. I think it put the starter through the sole of my Doc Marten once. I had to put on my motocross boots, mentally steel myself to rid all fear and give it a right old boot ... and maybe it would go. And if not I could be flailing away at it for some time, all knackered and sweaty.
When I came to sell it, some family came round to look at it and their jug eared, lanky teenage boy hopped straight on, flicked the kickstart with his trainer and was off up the (completely frozen snow) street, all hitting the power and sliding it about with no lid or any bike gear. The little fucker.
I think there's a knack to it. Or it's all in the mind. Either way, I don't have it.
iansoady
Has thanked: 59 times
Been thanked: 169 times
Post by iansoady »
That knurling looks a bit superficial - I'd coat it with grit.
derek badger
iansoady wrote: Sat Apr 03, 2021 10:17 am That knurling looks a bit superficial - I'd coat it with grit.
It's better then it looks in the photo. Skateboard grip tape is my plan if it starts slipping.
derek badger
The steel turned up. Need to start jigging and tacking things up and sort out the drive source.
derek badger
Right, so I dragged the Suffolk Punch mower out and welded up an intake manifold out of some 4mm plate and some steel tube. Attached a carb off a pit bike and it runs great. It's got a centrifugal clutch so it could be a goer if I can sort out a bearing mount for the shaft. It's also got a bunch of chains and sprockets in the end plate that might be useful.
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Post by Yambo »
You going to make a bracket for the bike so you can take the beast with you when you go out for a ride? :P
iansoady
Post by iansoady »
He could have it on a little (well quite big) trailer....
Been thanked: 2617 times
Take it to racetracks and offer a tyre profile adjusting service.
derek badger
Yambo wrote: Mon Apr 12, 2021 8:03 am You going to make a bracket for the bike so you can take the beast with you when you go out for a ride? :P
Lolz. No, I only need it to sort out the starting/running issue it currently has. Once it's running properly I'll probably sell the rollers.
