Would you buy a used MV Agusta?
bevvo
Has thanked: 83 times
Been thanked: 129 times
Post by bevvo »
I've been slightly swayed by some of the discussions on here suggesting that you should buy a bike that moves your soul, not just you arse.
I mean I always buy bikes that I think will have a bit of magic but I also consider reliability, parts availability etc. So Japanese, Triumph and even Aprilia. But now I have a bit more spending power, maybe I can look for something more desirable and exotic.
So I've been looking at used MVs. Something like a 800 Brutale of 2015 vintage in very tidy order can be had for 6-7 bags of sand.
E.g.
https://www.ebay.co.uk/itm/MV-AGUSTA-BR ... Sw6udgHUTB
But would you?
Been thanked: 15493 times
Re: Would you buy a used MV Agusta?
Nearly did 3 weeks back. 800 race bike.
Been thanked: 4529 times
Having owned a 2nd hand bike made by MV Agusta I'd be a bit wary, I had a 2002 Husqvarna 610, lovely bike to ride, but I had to strip it down and out it back together properly to stop bits falling off. I hope the more main stream bikes are better put together than that was, but I would be cautious.
My nearest bike shoppe is an MV dealer, I think I'd want a specialist within a reasonable distance if I were to own one.
Has thanked: 1926 times
Been thanked: 1728 times
MVs look lovely ...
For IL4s
The 800s are triples, and are well worth wanking over
bevvo
Post by bevvo »
Exactly! Reviews tell of much exitement and torque.
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Post by Bigyin »
Lovely bike, if you do buy it send the bloke you buy it from pictures of the tyres to show they can actually be leaned over :thumbup:
bevvo
Post by bevvo »
KungFooBob wrote: Thu Feb 18, 2021 7:05 pm My nearest bike shoppe is an MV dealer, I think I'd want a specialist within a reasonable distance if I were to own one.
I tend to fix my own bikes but you need to be able to source the bits. Plus, do i really want to be replacing warped fuel tanks at (guessing) £1k a pop...
I don't think you'll have any trouble getting parts, my Husky was the easiest bike I've had to get parts for, sadly I needed a lot of them.
Has thanked: 20863 times
Been thanked: 13684 times
To my mind that one you linked to is one of the best looking bikes out there. Well worth owning. Get it bought. :thumbup:
Ride it before you but it, some of them have the triangles of pain that dig into your thighs
Druid
Has thanked: 351 times
Been thanked: 1106 times
Post by Druid »
I bought a 2010 Brutale 990 about 3 years ago, kept it for 2 years and 6000 miles. It's the IL4, not the triple. Nearest dealer is a hundred miles away but I can't remember the last time I used a dealer, I'm prepared to tackle just about anything and the workshop manual comes with the bike. Service items are readily available online and are reasonably priced.
In the time I owned it, apart from service items I had 2 mechanical faults:
1) a clutch slave cylinder seal failed and was replaced for pennies,
2) the rear hub bearing developed a bit of play. MV say that you have to replace the hub as a complete unit at a cost of £ hundreds. Someone on the MV forum does an upgraded replacement which is still £several hundred. I sourced the bearings and replaced them myself for less than £60.
Le_Fromage_Grande wrote: Thu Feb 18, 2021 7:11 pm The 800s are triples, and are well worth wanking over
Off to have a look. Made in gnome size?
Mr Moofo wrote: Thu Feb 18, 2021 8:25 pm
I'm fine on one (apart from the triangles of pain) and I'm an optimistic 5ft 8, probably less than that now as I've started shrinking with age.
bevvo
Post by bevvo »
weeksy wrote: Thu Feb 18, 2021 7:02 pm Nearly did 3 weeks back. 800 race bike.
Why didn't you in the end?
bevvo wrote: Fri Feb 19, 2021 2:01 pm
It had sold before Mrs Weeksy pulled her finger out.
bevvo
Post by bevvo »
KungFooBob wrote: Thu Feb 18, 2021 7:33 pm Buy this instead.
https://www.ebay.co.uk/itm/Bimota-SB8R/ ... SwT~dgIlfG
Undeniably desirable and exotic. But its out of range, budget-wise and a bit too race-rep for me. I prefer bars rather than clip-ons, and less fairing.
bevvo
Post by bevvo »
weeksy wrote: Fri Feb 19, 2021 2:03 pm
Shame. It looked tasty.
