'83 GPz750-A1 malarkey.
Been thanked: 9506 times
Re: '83 GPz750-A1 malarkey.
ZRX61 wrote: Fri May 22, 2026 9:31 pm
KungFooBob wrote: Fri May 22, 2026 8:44 pm After you've tumbled them are you gonna replate them?
I've never tried it, but zinc replating looks doable at home.
No need here in the desert, they won't corrode :)
I did think that the moment after I posted :)
Has thanked: 2296 times
Been thanked: 2688 times
KungFooBob wrote: Fri May 22, 2026 9:33 pm I did think that the moment after I posted :)
Case in point.... Z1 gears that have been sat on a shelf in the garage for at least 20 years (I did blow the dust off before taking the pic)
More gubbins arrived...
ZRX61 wrote: Fri May 22, 2026 1:12 am Shipped:
ZRX61 wrote: Thu May 21, 2026 5:56 pm Manual(arrived)
Exhaust gaskets(arrived)
Tail/strakes/grab rail
Rear m/c
Side stand mount doodad(arrived)
Footpeg mounts
Brake caliper rebuild kits (3)
Carb rebuild kits (arrived)
Ignitor/pick up coils & plate etc (arrived & fitted)
Ignitor cover gasket (arrived)
Tank bungs (arrived)
Generator cover (arrived)
Fuel cross feeds & O rings (arrived)
Mirrors (arrived).... neither of which went on the GPz750, but the right one went on the GPz11.... so that doesn't really count.
Speedo/tach assembly (arrived)
Scored another set of carbs for parts from a mate for $20 + shipping, same guy who sold me the clocks for $25.
Dumped a shit-ton of screws from the carbs in the tumbler this afternoon.
Also dug out my tin of weird drill bits... it has tapered bits for wood screws....
and also these three bits which have a spring-loaded doodad that centers the bit when drilling pilot holes for door hinge screws...
The smaller one is the perfect size & depth for drilling into that buggered air screw on the #1 carb, & I deployed the screw extractors for use after I put a hole right in the middle of the air screw.
Raided the kitchen for this:
All set to drill out that buggered air screw now. Got the drill bit shown in the previous post & three different types* of extractor... NONE of which are those fucking E-Z Out mongfoolery. :)
*including a German #1 Rennsteig extractor.
YES!!! Behold the extracting GOD you lowly peasants!! :obscene-birdiedoublered: :obscene-birdiedoublered:
Rennsteig for the win!! :banana-dance:
Started with the self-centering hinge drill doodad to get the hole started, went up to a slightly larger bit & went to town (notice the brass swarf), Then put the Rennsteig in the hole, seated it with a couple of light hammer taps & then just unscrewed the jet. 8-) 8-)
The Amazon reviews of the German doodad had several people saying "Bought this to successfully remove a stuck jet in a Mikuni".. which I will be adding too.
FINALLY got the carbs separated. Issue was the choke rod which most online posts state "remove the screws & slide the rod out"... :eh:
Problem:
It doesn't have any fucking screws :angry-cussingblack:
Solution:
Found a post on KZRider from over a decade ago that mentioned Ping!FuckIts! & even listed the part # (92033-1066) Looked up the parts diagram & found the buggers. :thumbup:
Choke Rod.JPG (115 KiB) Viewed 1950 times
& once I popped those buggers off I could separate the carbs.
Tomorrow I might even pull the choke plunger assemblies. :think:
Choke plungers removed, carb bodies back in the ultrasonic.
...and back out again after an hour. Even managed to get the balls (# 92045)& springs (#22081-A) out of the two carbs that position the choke rod. Balls came out in the tank, springs removed after with a sharp pointy thing (scribe, for you technical types).
Ian
Has thanked: 1362 times
Been thanked: 582 times
Post by Ian »
ZRX61 wrote: Sat May 23, 2026 11:29 pm
.... Then put the Rennsteig in the hole, seated it with a couple of light hammer taps & then just unscrewed the jet. 8-) 8-)
Can you share a link please? I have some stuck airscrews in my RG
Ian wrote: Tue May 26, 2026 8:00 pm Can you share a link please? I have some stuck airscrews in my RG
I got it from Amazon, just punch "Rennsteig extractor" in the search bar. For carbs you want the #1 size. It's a Knipex company. If you don't tap it hard enough to seat it in the hole it will act like a tapered reamer, at which point another clout or two will have it seated enough to grip the brass carb doodad.
I started with a small drill bit, then went to 1/8in. Drilled in about 1/4in.
Then ran another old screw in to check the threads were ok, they are.
Santa dropped by again.... Ya win some, ya lose some...
Brake kits: Win! :thumbup:
Another tail: Win! (it has some parts attached that I want/need) :thumbup:
Kickstand: Lose. Ad showed parts that I need attached to it. Fucker didn't send those, didn't need the actual stand. :angry-cussingblack:
Has thanked: 10975 times
Been thanked: 4011 times
ZRX61 wrote: Tue May 26, 2026 9:45 pm
Looks like Rennsteig do both types: fluted and threaded :
From Amazon UK :
(https://www.amazon.co.uk/Rennsteig-471- ... 52ffba15af)
(https://www.amazon.co.uk/Rennsteig-470- ... 186&sr=8-9)
Looks like the no1 fluted is only a tenner individually:
(https://www.amazon.co.uk/Rennsteig-9R-4 ... 186&sr=8-8)
I'm thinking I'll just add that kit (top link) to my xmas list. :)
Another rear m/c showed up. Original (right) has a bolt sheared off in it, may attempt to remove broken bolt at some point...
Fired up the soda blaster in the driveway & knocked the paint off the carbs. :thumbup:
JHC!!! It looked like a scene from Scarface be the time I was done. Barely used any soda, but the mess was epic :shock:
Got done with that & put everything away, hosed off the driveway etc.. & just when I finished the other set of carbs showed up from Texas. :roll: I thought I was getting a partially stripped set, but they're complete :banana-dance:
So the Saturday plan is original carb bodies back in the ultrasonic & pull a couple of parts off the spare set.
and.. I just realized I forgot to soda blast the fucking float bowls. FFS :angry-cussingblack: :angry-cussingblack: :angry-cussingblack:
Not really an issue because other stuff will getting the soda treatment soon enough.
More gubbins showed up...
Soda'd carbs.
