Get a room.Skub wrote: Thu May 21, 2026 4:52 pmYou bought the Homda around the same time as I bought my Zed,we've covered similar miles (26k for me) and changed the front pads at the same time.Le_Fromage_Grande wrote: Thu May 21, 2026 1:37 pm It's now 6 years old, 19,500 miles, new brake pads fitted today, old ones has about 0.5mm of pad material left and had started to make a slight noise.![]()
It doesn't mean we're engaged or anything.
NBT: I've bought a Honda!
- Has thanked: 2286 times
- Been thanked: 2672 times
Re: NBT: I've bought a Honda!
- Has thanked: 12604 times
- Been thanked: 8535 times
I bought mine about same time.Skub wrote: Thu May 21, 2026 4:52 pmYou bought the Homda around the same time as I bought my Zed,we've covered similar miles (26k for me) and changed the front pads at the same time.Le_Fromage_Grande wrote: Thu May 21, 2026 1:37 pm It's now 6 years old, 19,500 miles, new brake pads fitted today, old ones has about 0.5mm of pad material left and had started to make a slight noise.![]()
I'm on 5th set of pads
It's your age. Sometimes excitement allows a little to escape,then those pads do their job.
- Has thanked: 602 times
- Been thanked: 4528 times
That's because you're only fast in a straight line and brake really hard for the corners then trickle round them just off verticalYorick wrote: Thu May 21, 2026 6:42 pmI bought mine about same time.Skub wrote: Thu May 21, 2026 4:52 pmYou bought the Homda around the same time as I bought my Zed,we've covered similar miles (26k for me) and changed the front pads at the same time.Le_Fromage_Grande wrote: Thu May 21, 2026 1:37 pm It's now 6 years old, 19,500 miles, new brake pads fitted today, old ones has about 0.5mm of pad material left and had started to make a slight noise.![]()
I'm on 5th set of pads![]()
Le_Fromage_Grande wrote: Thu May 21, 2026 8:32 pmThat's because you're only fast in a straight line and brake really hard for the corners then trickle round them just off verticalYorick wrote: Thu May 21, 2026 6:42 pmI bought mine about same time.Skub wrote: Thu May 21, 2026 4:52 pm
You bought the Homda around the same time as I bought my Zed,we've covered similar miles (26k for me) and changed the front pads at the same time.![]()
- Has thanked: 5953 times
- Been thanked: 3571 times
I've still got loads of pad left on mine at 11k and they are the originals. Either pads are lasting longer or I'm not riding like as much of a tit as I used to! Keep toying with the idea of switching to Brembo SA road pads to try and get some extra bite/feel, but the OE breaks aren't terrible, just not great and the Brembo are £48 a side. So yeah not bothered yet.
- Has thanked: 20853 times
- Been thanked: 13667 times
Actually that's a good about bikes of old. Until I was 30 I'd only keep a bike for 18 months or so.
Two pictures from today, taken at the same place but about 6 hours apart, last 3 days have been brilliant riding, probably hit 20,000 miles tomorrow
Buckaroo
- Has thanked: 1047 times
- Been thanked: 1108 times
Been out this morning, mileage is now 20002, which is nicely symmetrical.
