2nd floor extractor fan: allows a gale to blow into the bathroom!
- Mr Moofo
- Has thanked: 1926 times
- Been thanked: 1728 times
I have a top floor bathroom, which is always about 10 degrees colder than everywhere else in the house. As we are currently having to use the shower, it's kind of noticeable in the morning.
I am assuming there should be some sore of baffles or louvres withing the unit to address thi. Cetainly the exit apeture just seems to be a bunch of concentric circles. And I cannot get up that high to repalce it.
As the bathroom (other than at the moment) doesnt get used that often, I was considering some sort of cover ...
(Sorry for turning into Noggin)
- Has thanked: 8034 times
- Been thanked: 5692 times
Re: 2nd floor extractor fan: allows a gale to blow into the bathroom!
There's usually a couple of flaps in ceiling mounted ones that gravity keeps shut until the airflow from the fan lifts them* but dunno about wall mounted ones as gravity won't work.
* as can a strong wind so they can go 'clackclackclack'all night long in the en suite
- Has thanked: 778 times
- Been thanked: 3216 times
The 3 wall mounted ones we have here all have one of these on the outside wall
They do flap about if the wind is strong enough
- Been thanked: 2727 times
Fans with vent covers that open and close when the fan turns on and off are available.
- Mr Moofo
That’s what i was expecting. But that’s not what i have.MrLongbeard wrote: Thu Feb 12, 2026 6:09 pm The 3 wall mounted ones we have here all have one of these on the outside wall
Currently it has been isolated and covered with CD - which is a perfect size
- Has thanked: 316 times
- Been thanked: 1078 times
These fans are fitted from the inside and have a baffle / flap device in the tube.
https://www.screwfix.com/p/manrose-inte ... _container
- Mr Moofo
Thanks for that - I will now go and have a measure upSilly Car wrote: Sat Feb 14, 2026 4:55 pm These fans are fitted from the inside and have a baffle / flap device in the tube.
No worries, IIRC, you can also buy extensions for the telescope section for thicker walls.Mr Moofo wrote: Sat Feb 14, 2026 5:32 pmThanks for that - I will now go and have a measure upSilly Car wrote: Sat Feb 14, 2026 4:55 pm These fans are fitted from the inside and have a baffle / flap device in the tube.
https://www.screwfix.com/p/manrose-inte ... _container![]()
- formula400
- Has thanked: 482 times
- Been thanked: 1045 times
- Contact:
Jumping on this, is there anyone to stop them flapping???MrLongbeard wrote: Thu Feb 12, 2026 6:09 pm The 3 wall mounted ones we have here all have one of these on the outside wall
We have them and it makes it sounds like a basket ball being bounced
CBR650r
- Has thanked: 781 times
- Been thanked: 1072 times
There are different types, I have a flappy section inside a piece of duct. The exit for mine is covered so I don't need to try and stop rain getting in.
Try fitting one of these, there's a flap inside the cowl, you could stick a bit of foam to stop the flappy moise.
https://www.tlc-direct.co.uk/Products/F ... HwEALw_wcB
or alternativel, if there is a bit of ducting behind the fan, glue one of theses to the back of it,
https://www.cityplumbing.co.uk/p/manros ... 8Zlj9JEjjx
