Projects using JB Weld
Dave G
Has thanked: 88 times
Been thanked: 71 times
Re: Projects using JB Weld
Post by Dave G »
Unfortunatey I had to relocate the rectifier/regulator when I fitted the DOHC engine so it's no longer fitted.
Dave G
Post by Dave G »
This front sprocket cover is also all stuck together with JB Weld.
This pics shows it fitted.
NC450S engine_1.jpg (1.24 MiB) Viewed 1750 times
Very pretty job.
Dave G
Post by Dave G »
Thanks, this was the original plastic version, that looked cheap I thought!
Dave G
Post by Dave G »
Anybody else got any pics of projects using JB Weld?. Anybody getting inspiration to make bike bits?. Seem to be getting a lot of views but not many comments!.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
I'm very impressed by those panels. I have used JB weld a fair bit. One was fixing the crankcase on a 1931 Sunbeam Model 10. The bike is semi-wet sump and the area of the timing cover that should have sealed to the crankcase was chipped and hacked about to souldn't seal. Added to which it was a very narrow sealing face. As the model is very rare I wasn't confident about having it welded just in case so the trusty JB weld came in very handy.
Dave G
Post by Dave G »
iansoady wrote: Mon Jan 26, 2026 4:52 pm I'm very impressed by those panels. I have used JB weld a fair bit. One was fixing the crankcase on a 1931 Sunbeam Model 10. The bike is semi-wet sump and the area of the timing cover that should have sealed to the crankcase was chipped and hacked about to souldn't seal. Added to which it was a very narrow sealing face. As the model is very rare I wasn't confident about having it welded just in case so the trusty JB weld came in very handy.
Great got any pics?
Has thanked: 8034 times
Been thanked: 5693 times
I'd not seen JB-Weld before but I now feel that I need, nay, must have some. :D
I'm sure I'll be inspired to find lots of things to do with it. :thumbup:
Dave G
Post by Dave G »
Good, now's the time to do things while it's cold and wet outdoors!
iansoady
Post by iansoady »
I did have a look for pics of the JB weld repair but can't find any. But this is the bike. The offending area is around the plug below the exhaust.
Dave G
Post by Dave G »
Great pic, thanks. Hard to believe it's nearly 100 years old!. Must be worth a fortune, do you ride it much?
Dave G
Post by Dave G »
Here's a rear brake slave cylinder guard that I made from some 3mm scrap ally plate that was rolled around a 20mm former polished and then shaped. JB Weld was then used to fix the mesh behind the cut out.
Brake Actuator Cover.jpg (835.63 KiB) Viewed 1531 times
This is what it lokks like fitted.
Has thanked: 1183 times
Been thanked: 2277 times
This thread reads like someone discovering bread for the first time. Anyway, if you google "dave g" jb weld you'll see that Dave is quite the enthusiast for JB Weld.
Dave G
Post by Dave G »
Yes I think everone's got the picture now, it's good stuff.
Dave G
Post by Dave G »
Cover made to protect new hydraulic slave cylinder and finished off with stainless mesh fixed using the usual stuff.
iansoady
Post by iansoady »
Dave G wrote: Tue Jan 27, 2026 12:21 pm Great pic, thanks. Hard to believe it's nearly 100 years old!. Must be worth a fortune, do you ride it much?
I sold it on as I needed the room for another project. Re value: bikes like these have depreciated rapidly over the last couple of years. I covered my costs when I sold it so was quite happy although I suspect the buyer - if he still has it - may be less so.
I did ride it a few times but have to say hand gear change and feeble brakes made it something of a challenge. Here it is with me on it:
Has thanked: 5953 times
Been thanked: 3572 times
All looks good. No projects or pics as I have the mechanic ability of a blind badger with no arms. I do love someone else's project though.
iansoady
Post by iansoady »
Oh, this is the Sunbeam showing the exposed rockers. Quite hypnotic:
Dave G
Post by Dave G »
What a gorgeous bike, luv it. It must give you great joy to ride it.
iansoady
Post by iansoady »
It did indeed but as I say needed to pass it on. My current project (a BSA/ Suzuki DRZ-400 with a Steib sidecar) has no JB weld used in its construction. Yet.......
