Projects using JB Weld
Dave G
Has thanked: 88 times
Been thanked: 71 times
Post by Dave G »
Has anybody else got examples of motorcycle projects held together with JB Weld. I've been using the stuff for probably 5 years now and the uses seem to be endless. I always wanted to make things but without a welder this was almost impossible until I discovered this product. Here's one example.
I used some scrap bits of ally and 4mm plate to make these radiator side cheeks.
All parts stuck together with JB Weld.
Here's a couple of pics before I got the DOHC badges from USA.
Re: Projects using JB Weld
It's stuff I've never used. Your efforts look cool,though.
Has thanked: 1926 times
Been thanked: 1728 times
Used it to weld the mounting points back onto 1994 Speed Triple body work. Still holding at the moment ...
But not in the league of the above
Dave G
Post by Dave G »
Amazing glue, once you've used it you'll never use araldite again!.
Dave G
Post by Dave G »
Here's a chainguard that I made from some scrap 'U' section ally and glued the fixing stanctions with JB Weld.
Top chainguard is the original.
Has thanked: 8034 times
Been thanked: 5693 times
Just been reading about it. 2-part epoxy with steel filler in. Looks useful stuff and the examples above are pretty convincing! :thumbup:
They even say they've repaired engine blocks with it.
Wiki - https://en.wikipedia.org/wiki/J-B_Weld
Dave G
Post by Dave G »
Yes I've even used it to modify the shape of the inlet port!
In the 70s I used stuff like an aluminium putty called Devcon. It had it's uses,but if the thing needed welded,it was a poor option.
DefTrap
Has thanked: 1838 times
Been thanked: 1468 times
Post by DefTrap »
I used it to plug a hole in a core plug in an almost unreachable spot on the back of a 406 motor (it was pissing coolant like a hose). Still holding 50k later.
Dave G
Post by Dave G »
Yes I remember once using some metal putty to try and recover a stripped thread, but it failed miserably
Ssray
Has thanked: 209 times
Been thanked: 214 times
Post by Ssray »
I've used it for at least 30 years.....
To test it we cleaned two scrap valve faces , JB welded them together, after setting we put one end in a vice and dropped a hammer from different heights, starting low of course, it took a far few hits and height to brake the jb weld
Has thanked: 2556 times
Been thanked: 4167 times
I used JB Weld to repair the table on a pillar drill that had the 'arc of shame' where people had drilled through the table, leaving it looking like swiss cheese. I then got it surface ground flat and it's been fine for years. Also used JB weld to bond two 'wedges' to the top plate of my Falco top yoke so it had a flat surface to mount risers on. Been great for nearly three years.
and another view:
I used JB Weld to fix the dilithium crystal articulation frame in the warp core of my Excelsior class starship and it's been fine.
Dave G
Post by Dave G »
I used JB Weld to reshape the inlet port on my dohc engine. The engine had a recess at the top of the inlet port to assist fuel injection but since I'd fitted a carb this wasn't needed so I filled it in. I first drilled and threaded the top of the port and secured some ally mesh into the recess, I then filled it with JB weld. Finally I smoothed an polished the newly filled area. I did similar to the inlet port adapter to match them together.
Before
after
Inlet port adapter shape modified with ally mesh and JB Weld
Inlet port adapter before modifying showing bottom ridge
Modified adapter fitted to inlet port (Ridge now gone)
Has thanked: 316 times
Been thanked: 1078 times
Post by Silly Car »
I used JB weld to repair a cylinder head mounting on my R1.
I attempted to remove a set of cheap shite upper crash bungs and the bolt sheared. I attempted to drill out / use easi-out stud removers and as the wedged shaped tool bit into the seized bolt, it split the casing and the broken stud just fell out.
JB weld on the broken shard, remaining threads and hand tighten bolt saw a ‘temporary’ fix that lasted all 10+ years I owned the bike. I did pick up another cylinder head with a view to getting that ported, flowed, tuned whatever before installing but it remained in a box long after the bike was sold.
As far as I’m aware that fix is still holding fast.
Dave G
Post by Dave G »
Magic stuff isn't it!. Didn't realize it had been around that long, wish I'd found it sooner!
Dave G
Post by Dave G »
Made up these side panel badges. Basically the letters were cut out of 3mm scrap ally then glued with JB Weld to some 4mm plate. Then some masking, black spray and polishing.
I heard the Virgin Mary became pregnant after using some JB Weld to fix her push iron.
Has thanked: 713 times
Been thanked: 2036 times
I was putting a gearbox on a RWD Mk6 transit engine. Bugger would not line up properly so started to tighten top nuts to straighten it up more. Heard a crack and seen a six inch line up the back from the bellhousing area. Once all back together i put JB weld up the crack and never had any issue with it. I stupidly changed a DMF for a solid that day and regretted it instantly but due to the crack i was not going back in.
Dave G
Post by Dave G »
Here's another project I did, it's a cover for a rectifier/regulator that's stuck together with JB Weld.
