Tool purchases
- Has thanked: 1445 times
- Been thanked: 1329 times
Re: Tool purchases
Needed some cheap/disposable scrapers. Bought these, then I dressed the blades & turned them into keepers.
https://www.harborfreight.com/4-piece-s ... 4wEALw_wcB
- Has thanked: 1326 times
- Been thanked: 1652 times
Re: Tool purchases
Just got a shorty screwdriver/bit holder.
Its made by Tengtools and the kind of thing thats sometimes handy for adjusting the speed settings of door closers when theres a low door reveal too close to the closer for a normal length screwdriver*
The photos perspective doesn't show perfectly but its only about 45mm long (or about 1/10th of a cubit to our elderly or American cousins) and has a 1/4" hex for screwdriver bits and square drive for small sockets on the ends.
Its got one of those gearless ratchet mechanisms with what I guess is a roller clutch?
Handy for getting into small spaces as long as youre not putting masses of torque on it.
I have a Snap On shorty ratchetting screwdriver which is possibly the nicest to use I've ever owned but its still sometimes too long so got this.
*Usually when some chull tip has insisted on having the closer fitted Regular Arm instead of the simpler, faster and neater Parallel Arm way. There are sometimes good reasons to do it regular arm but usually its just done cos the gaffa doesn't understand how parallel arm works and screams and screams til he's sick about it.
- Has thanked: 1204 times
- Been thanked: 798 times
- Has thanked: 16251 times
- Been thanked: 3745 times
Re: Tool purchases
That looks awesome!!! Might have to save up for one for the apartment - could get rid of a selection of other stuff then!! LOL
I need to buy a couple of spare 10mm for the big tool box in the garage!!v8-powered wrote: ↑Fri Nov 13, 2020 11:06 amI must be unique as I have a good stock of 10mm sockets, its 13mm spanners I have an issue with....
Re: Tool purchases
I do need to buy (in the spring - not mechanicking in the winter!!) a new ratchet 'handle' thingy for using with the sockets. The medium sized one I have, the thing that changes the direction has broken
Given I'm not professional and am somewhat kak-handed, any recommendation for brands types etc? Think it's a 1/4 inch square fitting but need to check
Re: Tool purchases
I have got some Halfords Pro stuff. If I don't need it before I visit I might go for a little shop when I eventually visit next year!! LOL
I'll put the other names on my list
Thank you
Re: Tool purchases
Bosch "multitool". Like a big uncomfortable vibrator (steady).
It gets into places no other tool can, performs cuts no other tool is able. Don't use it much but when you need to make a particular cut, nothing else is capable.
- Has thanked: 140 times
- Been thanked: 470 times
Re: Tool purchases
Nice! I’ve got a 240v one, it is exactly as you’ve outlined:
Need to cut a copper pipe that is tight to the wall, multi tool it.
Need to trim laminate flooring back in a door frame, multi tool it
Need to open up a hole in a plasterboard wall but done want to snag wires with a pad saw, multi tool it
The detail sander attachment is pretty good as well.
Re: Tool purchases
A set of extra long/stubby allen keys, great for when you can't get in with a normal length one
Re: Tool purchases
The one I have for work is made by Hitachi looks like this...
Not one of these though, thats a different Hitachi multitool altogether.
- Yambo
- Has thanked: 614 times
- Been thanked: 1632 times
Re: Tool purchases
Mine looks like this:demographic wrote: ↑Tue Dec 29, 2020 5:11 pm
There are times when it's the only tool for the job. I would have preferred the 18V one but it wasn't available, and still isn't.
Re: Tool purchases
Like DEADPOOL says, multitools are one of those tools I don't need often but when I do they save me a lot of pissing abut trying to get a neat cut with a handsaw in a tight space.
One for instance would be fitting an extra kitchen base unit where the wall has been skirted and I either have to remove the skirting and xut it down before refitting it or cut it in-situ using a handsaw moving just a few teeth at a time so I dont damage the existing flooring.
Or I try to gently chisel it to size without rattling the skirting off the wall. Its a faff.
Now with a multitool I hold a block of wood on the good side of the cut so it acts as a guide. Use the multitool and about thirty seconds later its done and the plinth for the new base unit goes upto it neatly.
Generally I just use the hacksaw type blades for most things cos I don't find the woodsaw ones last once I've hit plasterboard a time or two and the cut doesn't seem to take a lot longer anyway.
Hell, even the plumbers are cutting neater holes in buildings with them nowadays.
Used to be not so long ago the plumbers best tool for cutting neat holes in a plasterboard wall was an adjustable spanner...
Re: Tool purchases
demographic wrote: ↑Wed Dec 30, 2020 8:34 am Used to be not so long ago the plumbers best tool for cutting neat holes in a plasterboard wall was an adjustable spanner...
Re: Tool purchases
What I'm really after at the moment is a portable tablesaw setup with accurate fence system.
I really rate the Incra fence system this bloke uses on his router table and think that it could work well with a Triton tablesaw module. Will need a no volt release switch but thats not rocket science.
- Yambo
Re: Tool purchases
If I've got a DeWalt cordless drill and screwdriver thingy, would the battery fit a cordless version of this?
Re: Tool purchases
My wife has the 18 volt (the Yanks call em 20 volt MAX but thats Yanks for yer, always enflating the numbers) cordless version of that multitool and it runs on the same slide in batteries her drill and rattle gun. Same batteries as my cordless first fix nailgun, cordless planer, worklight, and Jigsaw I have as well.
I'm pretty sure it'll also run on the De-Walt Flexvolt batteries which have dual voltage (18/54 or 20/60 volt if yer insecure and need a gun to walk to the shops) depending on what they're plugged into.
If your wondering about Flexvolt, its a way to configure the cells either in group of parallels for the 18 and 20 volts or in series for the 54 and 60 volts setup.
So in short, yes the multitool with the slide in batteries runs on the same slide in batteries as the other gear.
The De-Walt multitool is dead easy to change blades on as well.
