2CV6 Project Thread
Been thanked: 3504 times
Re: 2CV6 Project Thread
dern wrote: Mon Mar 24, 2025 10:23 pm Not so much salt on the roads so the 2cv is mot’d and out and about in its new home in Norfolk. However was driving it the other day with the roof down, uphill and into a head wind and struggled to go much over 50 so it’s upgrade time, when I get time.
Donor engine obtained…
It’s a 2001 r1100rt with 40k on it. Pretty tidy although that doesn’t really matter and the engine sounds perfect, really quiet and smooth. Got it for £500 because the gearbox is broken and I don’t need that.
What motor does the CV have in it. ?? Interesting project this @dern 👍
Has thanked: 10959 times
Been thanked: 3995 times
Those panniers are worth £200 easy, you'll get your money back on the rest of the plastics no worries.
Has thanked: 7618 times
mangocrazy wrote: Mon Mar 24, 2025 10:31 pm Is the 2CV motor going into the RT? :D
Hmmm ... Would the gearbox fit? :shifty:
Dodgy69 wrote: Tue Mar 25, 2025 7:41 am
Just read earlier post. 👍
Has thanked: 1183 times
Been thanked: 2277 times
Rockburner wrote: Tue Mar 25, 2025 8:12 am
The first step will be stripping it down, working out what I need and what I don't and ebaying/scrapping the rest. I should get a few quid for the bits.
Do you use the BMW efi or the Citroen carbs?
Or is there a megasquirt project on the horizon?
Sadlonelygit wrote: Wed Aug 23, 2023 8:42 pm
Mussels wrote: Sat Aug 19, 2023 7:41 pm I think that's the best designed car I've ever seen.
All* the triumph sporty motors of the 60s/70s had flip front bonnets where you could sit on the front wheel whilst balancing the carbs/points/valves etc
*Tr7, sprint and stag excluded
But didn't they smart when the wind blew them back down...
KungFooBob wrote: Tue Mar 25, 2025 10:16 am Do you use the BMW efi or the Citroen carbs?
It'll use the whole bmw throttle body, injection system with the standard ecu. If I can find one I'll see if I can get a power commander for it but I think that they've been discontinued. I'll see how it runs without it and go from there. Emerald are based in the same town as me so that's an option if it really doesn't run how I want it.
I've just got an insurance quote which is much better than I expected so I'll order the conversion kit later today. It'll be a slow build though with other things going on.
dern wrote: Tue Mar 25, 2025 11:00 am
Look for a John Gemi chip. It's a complete replacement ECU chip that fits into the Motronic box. Find the guy on Facebook and tell him what your doing. He could probably make you a custom chip specifically for your use case. He seems easy to contact and talk to from what I've seen.
dern wrote: Tue Mar 25, 2025 10:10 am
I would claim dibs on the panniers, but I've already got 2.5 sets....
Rockburner wrote: Tue Mar 25, 2025 11:39 am
Let me know if you need anything. I'll be selling the 3 panniers with the ignition lock, the tank lock and the locks from side panels together with 2 keys. I won't be rushing to strip this all down though I'm afraid.
Rockburner wrote: Tue Mar 25, 2025 11:38 am Look for a John Gemi chip. It's a complete replacement ECU chip that fits into the Motronic box. Find the guy on Facebook and tell him what your doing. He could probably make you a custom chip specifically for your use case. He seems easy to contact and talk to from what I've seen.
Will do, thank you very much.
I spoke to John Gemi (if that's his name) and he's sending me an ecu for my application this week. I should get the adapter kit this week too. I just need to clear the decks of other projects and practice my stainless exhaust welding and away we go.
Finally motivated to get it out of the van as I need to pick up some furniture for my daughter. Took it for a run up the road and I can't see that there's anything wrong with the gearbox. Rides like a bloody lump though, don't feel bad at all splitting it for parts.
The fitting kit for the 2cv has arrived as well as the John Gemi chip. I just need to clear the decks of projects and start stripping the bmw down in a couple of weeks.
dern wrote: Thu Apr 24, 2025 3:26 pm lump.jpg
Get in touch if you have any questions about servicing etc. I don't know everything about them - but should have the basics covered if there's anything that's not clear. :)
The gearbox "issue" may have been a lack of knowledge about how they're best managed.
Rockburner wrote: Thu Apr 24, 2025 3:30 pm
Get in touch if you have any questions about servicing etc. I don't know everything about them - but should have the basics covered. :)
Will do, thanks. You don't know what the downpipes are made do you by any chance? I need to cut and weld them. I'm assuming stainless but will have to check if I can't find out.
dern wrote: Thu Apr 24, 2025 3:32 pm
Yes - stainless. IIRC they're not that thick. I've only cut the entrances to the catalyst off and they're 5 minutes with a hacksaw - the main downpipes won't be much thicker.
Ok, thanks. I'll get some practice pipe and get some tig time.
I've put together a quick list of parts I can sell. I checked on ebay and basically undercut all the prices and none of them seem that unreasonable to me. I've concentrated on the crash damage parts...
Parts to sell Price
Full fairing 150
Luggage and lock set 150
Wheels 100
Clocks 50
Headlight 30
Screen motor 30
Rear light 30
Handlebars 30
Main fairing frame 50
Rear subframe 30
If I get anything like that I'll make my money back and get a free engine. There's a load of other smaller stuff that probably isn't worth that hassle of ebaying.
Has thanked: 2556 times
Been thanked: 4167 times
Those prices look excessively reasonable to me. Beware of getting your arm bitten off...
