Questions that need to be answered
Re: Questions that need to be answered
I'd guess its cause engines were typically done in cubic inches / freedom units. Cubic centimeters feels like less of a surrender to the commie metric system, despite it being both A) metric, and B)the same size as a millilitre.
- Has thanked: 8039 times
- Been thanked: 5694 times
Some of our Mint Imperial units still work bestest though. eg mph and psi. Them forrin equivalents, inc the Merkins with their squitty little 'gallons', are rubbish.Mr. Dazzle wrote: Fri Feb 07, 2025 8:11 am I'd guess its cause engines were typically done in cubic inches / freedom units. Cubic centimeters feels like less of a surrender to the commie metric system, despite it being both A) metric, and B)the same size as a millilitre.
Edit: bhp is
- Pirahna
- Has thanked: 3010 times
- Been thanked: 1749 times
Perhaps a change to cups or tablespoons?Saga Lout wrote: Fri Feb 07, 2025 4:55 am Why do we use cc and litre for engine sizes? We should be consistent and use millilitres and litres.
(Or centilitres,)
My current car does tyre pressures in kPa on it's dashboard systems, the last one did too (funny that, what with it being basically the same modelCount Steer wrote: Fri Feb 07, 2025 8:44 amSome of our Mint Imperial units still work bestest though. eg mph and psi. Them forrin equivalents, inc the Merkins with their squitty little 'gallons', are rubbish.Mr. Dazzle wrote: Fri Feb 07, 2025 8:11 am I'd guess its cause engines were typically done in cubic inches / freedom units. Cubic centimeters feels like less of a surrender to the commie metric system, despite it being both A) metric, and B)the same size as a millilitre.
Edit: bhp istoo.
2.8bar if you prefer, which is what lots of pumps read in.
- Has thanked: 7621 times
- Been thanked: 5929 times
NY previous previous proper job (before a sideways shift, then redundancy) involved working in both imperial and metric.Count Steer wrote: Fri Feb 07, 2025 8:44 amSome of our Mint Imperial units still work bestest though. eg mph and psi. Them forrin equivalents, inc the Merkins with their squitty little 'gallons', are rubbish.Mr. Dazzle wrote: Fri Feb 07, 2025 8:11 am I'd guess its cause engines were typically done in cubic inches / freedom units. Cubic centimeters feels like less of a surrender to the commie metric system, despite it being both A) metric, and B)the same size as a millilitre.
Edit: bhp istoo.
Conversions never caused problems, oh no, never
We were designing printed circuit boards, where a track width of a single digit (e.g. "8 thou") is much easier to determine (by the electronics engineer) and describe than its metric equivalent.
- Has thanked: 10964 times
- Been thanked: 3995 times
40psi??Mr. Dazzle wrote: Fri Feb 07, 2025 9:15 amMy current car does tyre pressures in kPa on it's dashboard systems, the last one did too (funny that, what with it being basically the same modelCount Steer wrote: Fri Feb 07, 2025 8:44 amSome of our Mint Imperial units still work bestest though. eg mph and psi. Them forrin equivalents, inc the Merkins with their squitty little 'gallons', are rubbish.Mr. Dazzle wrote: Fri Feb 07, 2025 8:11 am I'd guess its cause engines were typically done in cubic inches / freedom units. Cubic centimeters feels like less of a surrender to the commie metric system, despite it being both A) metric, and B)the same size as a millilitre.
Edit: bhp istoo.
). I could no doubt go into the settings and change it, but honestly I CBA and I've just recalibrated my thinking
Correct pressure is 280kPa.
fecking hell, what are you driving, a Routemaster???
I was one of those 'lucky' ones that had to learn the traditional UK system and CGS and MKS.
At Uni we had an old, quite eccentric, physics lecturer who said 'Units? Bah. Nothing to be afraid of. Now, calculate the emf - in V/m and gauss - developed by a metal ship's mast. The mast is x cubits long, the ship is travelling through the earth's field on an ESE bearing at y leagues per fortnight. Crack on'.
Yeah I was a bit surprised too, but that's the number. It's a fairly typical big German saloon.Rockburner wrote: Fri Feb 07, 2025 9:24 am
40psi??
The old one, which was nearly the same car (even the same wheel design) was 270kPa. For some reason petrol engines add those last 10kPa.
Saga Lout
- Has thanked: 600 times
- Been thanked: 749 times
My point was why do we use a solid (or volume) measure, i.e. cubic centimetres, for small engines but use a liquid measure, i.e. litres, for larger engines? My guess is: because we do, that's why.
- Has thanked: 779 times
- Been thanked: 3216 times
A cold beer's got twelve ounces, A good truck's got maybe three hundred thousand.
My car is the first car I've ever had where the front and back tyres are different pressures, 43 psi front, 33 psi rear. Bloody GermansRockburner wrote: Fri Feb 07, 2025 9:24 am40psi??Mr. Dazzle wrote: Fri Feb 07, 2025 9:15 amMy current car does tyre pressures in kPa on it's dashboard systems, the last one did too (funny that, what with it being basically the same modelCount Steer wrote: Fri Feb 07, 2025 8:44 am
Edit: bhp istoo.
Litres aren't a liquid measure, they're also a measure of volume. Hence why you have balloons measured in litres for example.Saga Lout wrote: Fri Feb 07, 2025 9:53 am My point was why do we use a solid (or volume) measure, i.e. cubic centimetres, for small engines but use a liquid measure, i.e. litres, for larger engines? My guess is: because we do, that's why.![]()
- Pirahna
My T6 Kombi runs 58psi in the front and somewhere between 50 and 58psi in the back.
High or low profile tyres?Pirahna wrote: Fri Feb 07, 2025 10:32 am My T6 Kombi runs 58psi in the front and somewhere between 50 and 58psi in the back.
I "believe" (but not sure) that lower profile tyres would need a higher pressure to ensure that any bigger bumps don't incur tyre-carcass > wheel rim interfaces.
I was gonna say mine aren't low profile, but that's not true, they probably are - it's just that our mental calibration of what 'low profile' means has shifted. They're 255/35.
They're also lined with noise abating foam
All of which makes them nearly £300 to replace when you get a puncture
- Pirahna
215/60/17 standard VW fitment. I had some 70 profile tyres on the Crafter which were at 70psi.Rockburner wrote: Fri Feb 07, 2025 12:00 pmHigh or low profile tyres?Pirahna wrote: Fri Feb 07, 2025 10:32 am My T6 Kombi runs 58psi in the front and somewhere between 50 and 58psi in the back.
- Cousin Jack
- Has thanked: 3004 times
- Been thanked: 2522 times
And they will need replacing. Same size as mine, and they last about 10k miles.Mr. Dazzle wrote: Fri Feb 07, 2025 12:42 pm I was gonna say mine aren't low profile, but that's not true, they probably are - it's just that our mental calibration of what 'low profile' means has shifted. They're 255/35.
They're also lined with noise abating foam![]()
All of which makes them nearly £300 to replace when you get a puncture![]()
Did 18k on the last set before giving the car back, they still had 3.1mm left. Fleet services have got a nifty little doodad in the floor, you drive over it as you go into the returns bay and it measures all four tyres.Cousin Jack wrote: Fri Feb 07, 2025 1:27 pmAnd they will need replacing. Same size as mine, and they last about 10k miles.Mr. Dazzle wrote: Fri Feb 07, 2025 12:42 pm I was gonna say mine aren't low profile, but that's not true, they probably are - it's just that our mental calibration of what 'low profile' means has shifted. They're 255/35.
I was worried for a moment, 'cause you have to give the cars back with >3mm of tread, but I wasn't aware the 18 month leases had a bigger tread wear allowance and I could have gone down to 2mm. Shoulda done some doughnuts in the carpark.
This was on a 250bhp rear wheel drive car too and I wouldn't say I drive like a granny.
Saga Lout
My Mazda has 225/45R19, the slightly lower spec model has 225/55R17, the manual says they both need 33psi.Pirahna wrote: Fri Feb 07, 2025 1:19 pm215/60/17 standard VW fitment. I had some 70 profile tyres on the Crafter which were at 70psi.Rockburner wrote: Fri Feb 07, 2025 12:00 pmHigh or low profile tyres?Pirahna wrote: Fri Feb 07, 2025 10:32 am My T6 Kombi runs 58psi in the front and somewhere between 50 and 58psi in the back.
- Pirahna
Your car isn't a van. I only made the original comment on reply to someone who was surprised at higher tye pressures. From memory I think my Caddy ran the fronts at 40psi. My Duster has the same size tyres as the T6 and runs 33psi.Saga Lout wrote: Fri Feb 07, 2025 1:34 pmMy Mazda has 225/45R19, the slightly lower spec model has 225/55R17, the manual says they both need 33psi.Pirahna wrote: Fri Feb 07, 2025 1:19 pm215/60/17 standard VW fitment. I had some 70 profile tyres on the Crafter which were at 70psi.Rockburner wrote: Fri Feb 07, 2025 12:00 pm
