Ultrasonic Cleaners
Ultrasonic Cleaners
Any recommendations?
I was looking at this one. It'll probably be used for things the size of carburettors,etc. Also any heads up on the best cleaning fluid?
https://www.amazon.co.uk/dp/B087JFRYM6? ... 9jm5u5eqkv
Has thanked: 10959 times
Been thanked: 3995 times
Re: Ultrasonic Cleaners
LOL - I bought the 10l one only last year. :D (eek - that was in '23! :wtf: ) (Which they seem to have stopped selling). FWIW I think you'd struggle to get a carb body into the smaller ones. I'd go for at least 5L. Mine is 10L and would take an entire Amal Monobloc with room to spare, but it's actually not as deep as you might think.
Looks like the prices have sky-rocketed.... I only paid £110 for my 10l. :(
I would say bring your stuff over here ..... but that's a bit of a trek for you! :D
IIRC I found that this stuff got good reviews and recommendations :
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
De-ionised water
https://www.amazon.co.uk/dp/B00X30OJWO? ... asin_title
These are also handy for tiny stuff.
https://www.amazon.co.uk/gp/product/B0B ... UTF8&psc=1
Re the de-ionised water - I "believe" you can "grow your own" if you have a de-humidifier - but I've not tried it yet.
Re: de-isonised water and dehumidifiers.
I've got a dehumidifier to make my washing dry quicker. Obviously the question "what does this water taste like?" entered my silly little brain when I emptied it.
Exactly like battery top up water, can confirm. :thumbup:
You shouldn't drink ONLY deionised water BTW, but a taste won't hurt you :D
Mr. Dazzle wrote: Mon Jan 13, 2025 9:52 am Re: de-isonised water and dehumidifiers.
I'm not sure what's more worrying....
that you've tasted the water out of your dehumidifier... or that you've drunk battery water!
Only the unused stuff :D
Mmm. I'd imagined the 3l model would take a carb,but they don't give any other dimensions,so maybe best err on the side if caution and go for bigger. 6l is next,then 15l. I'll have a think about that.
On the plus side,I empty plenty of water from the dehumidifier down the drain,so that would be a neat recycling trick. Do you add in any cleaner to the water,or will the ultrasonic clean it without?
Skub wrote: Mon Jan 13, 2025 10:42 am Mmm. I'd imagined the 3l model would take a carb,but they don't give any other dimensions,so maybe best err on the side if caution and go for bigger. 6l is next,then 15l. I'll have a think about that.
I'd imagine the cleaning solution would chemically eat away at the grime, while the ultra-sonics act as a "catalyst" to that action, so yeah - using the solution would be beneficial.
rusty
Has thanked: 41 times
Been thanked: 28 times
Post by rusty »
I've had one of the 10 litre Vevor ones for a coupe of years and it's been pretty good.
To save a fortune on the cleaning solution it's worth trying what this guy recommends:
rusty wrote: Mon Jan 13, 2025 11:12 am I've had one of the 10 litre Vevor ones for a coupe of years and it's been pretty good.
If I remember... I'll probably try that next time I use the thing. The whole cleaning out of the entire "sink" did bother me and I do remember thinking "there must be a better way to do this...".
:lol: I just watched that an hour ago. Some cool tips in there.
Skub wrote: Mon Jan 13, 2025 12:05 pm
I'm now racking my brains to figure out what lovely foods to buy so I can amass a stock of suitably sized plastic containers..... :D
Has thanked: 2556 times
Been thanked: 4167 times
I've got a small(ish) 10 litre ultrasonic cleaner and a 30 litre one. The 10 litre comfortably takes a single carb, the 30 litre comfortably takes a bank of 4 VFR carbs while still bolted together in a V. Dunno if it would manage a bank of IL4 carbs or not.
One thing I discovered early on is that you need to properly degrease any items before you put them in the cleaner, as it hardly touches grease. Give anything greasy a really good going over with your solvent of choice and make sure they are free of any grease residues. then dump them in the ultrasonic tank. Carb cleaning fluid for ultrasonic cleaners is available on eBay.
We used to have one full of degreaser at my old place. It was refrigerated so the fluid would stay in the tank and not evaporate away to gas anyone standing nearby :D
Worked a treat on almost anything.
Druid
Has thanked: 351 times
Been thanked: 1106 times
Post by Druid »
I have a 750ml cleaner, it is just about big enough for a single carb. For cleaning I use citric acid crystals dissolved in water. Citric acid crystals are cheap and available from chemists or home brewing suppliers
rusty
Post by rusty »
Rockburner wrote: Mon Jan 13, 2025 12:09 pm
I ended up using Ikea ziplock bags with the fluid and the parts inside the bag. Seemed to work well.
Druid wrote: Mon Jan 13, 2025 1:33 pm I have a 750ml cleaner, it is just about big enough for a single carb. For cleaning I use citric acid crystals dissolved in water. Citric acid crystals are cheap and available from chemists or home brewing suppliers
One thing to be aware of - citric acid at higher concentrations will not only remove rust, but also zinc plating and passivation. So if your carb bodies are a zinc composite, use low concentrations and check them frequently.
I use muslin/string bags to hold small parts. Makes fishing them out a lot easier.
Has thanked: 2287 times
Been thanked: 2673 times
mangocrazy wrote: Mon Jan 13, 2025 12:27 pm I've got a small(ish) 10 litre ultrasonic cleaner and a 30 litre one. The 10 litre comfortably takes a single carb, the 30 litre comfortably takes a bank of 4 VFR carbs while still bolted together in a V. Dunno if it would manage a bank of IL4 carbs or not.
Easily.
