Need to get this sucky thing off!!
- gremlin
- Has thanked: 824 times
- Been thanked: 4914 times
Re: Need to get this sucky thing off!!
Have you unsucked yet? If not just slide a pointy kitchen knife between it and the screen. If it's just the vacuum holding it, it should pop off. If somebody has glued it, you'll be able to prise it off. Do not run with the knife, point it at yourself or attempt to otherwise interact with the pointy end.
- Has thanked: 218 times
- Been thanked: 693 times
You do realise this is Noggers? The original FUF????Tomcat wrote: ↑Fri Feb 23, 2024 5:21 pm Have you unsucked yet? If not just slide a pointy kitchen knife between it and the screen. If it's just the vacuum holding it, it should pop off. If somebody has glued it, you'll be able to prise it off. Do not run with the knife, point it at yourself or attempt to otherwise interact with the pointy end.
- Has thanked: 16512 times
- Been thanked: 4045 times
I did! It’s not a ‘clean’ plastic vacuum thing. It’s soft plastic and it’s proper sticky!!! But at least I can remove it now - without a knife !!! (TBF, whilst the French do allow carrying of knives, it’s not something I’ve done yet, and don’t want to carry a kitchen knife or have to go home for one each time I change véhicule!!! )Tomcat wrote: ↑Fri Feb 23, 2024 5:21 pm Have you unsucked yet? If not just slide a pointy kitchen knife between it and the screen. If it's just the vacuum holding it, it should pop off. If somebody has glued it, you'll be able to prise it off. Do not run with the knife, point it at yourself or attempt to otherwise interact with the pointy end.
- Has thanked: 508 times
- Been thanked: 1483 times
I have a big Chefs knife in the back of my van. Its handy for cutting turf officer, honest.
TBF i have been considering a pocket knife à la Fronch, but I know what everyone will say if I get one
Ok. This bastarding sucky thing now has the opposite issue. It refuses to stick to the screen
Any ideas how to make it sticky again??
- Cousin Jack
- Has thanked: 2650 times
- Been thanked: 2380 times
Buy a new one.
Most of those 'sucky things' are very dependent on the edge being near perfect to get a good seal. Hacking it off with a CC or knife, or poking a screwdriver into it soon wrecks the seal.
DAMHIKT
DAMHIKT
It's more that it used to be 'tacky', so the suction bit just forced the tacky bit to stick properly. Now it isn't tacky, so even with the suction it's not sticking (the cold probably doesn't help much I'd guess )Cousin Jack wrote: ↑Sun Dec 08, 2024 5:59 pm Buy a new one.
DAMHIKT
Trying not to buy one till I get to buy a car of my own!! But, might have to I guess
