A very slow possible resurrection of an Aprilia TXR312 trials bike
- Been thanked: 2612 times
It was delivered yesterday:
A quick look over the bike and the box of bits suggests it's all there. Both tyres hold air which is a start, it's easier to push about. Turning it over by hand suggests there's compression. It might need fork seals too.
The first thing to do is get it running. I can check for a spark by spinning it up with a cordless drill. Once that's done I'll sort the carb.
- Has thanked: 5449 times
- Been thanked: 13085 times
Re: A very slow possible resurrection of an Aprilia TXR trials bike 312
it might need a bit more than fork seals... I hope it was less than £20.
- Been thanked: 7526 times
Re: A very slow possible resurrection of an Aprilia TXR312 trials bike
You can re-chrome the forks by rubbing them with a bit of balled up tin foil
- Has thanked: 614 times
- Been thanked: 405 times
Oh wow. Good luck with that! Although if anyone can do it, you can.
- Has thanked: 9819 times
- Been thanked: 10144 times
Happy new project day.
Is it done yet?
Is it done yet?
Buy shares in Alcoa.KungFooBob wrote: ↑Fri Sep 20, 2024 11:28 am You can re-chrome the forks by rubbing them with a bit of balled up tin foil
First problem: I haven't got a spark plug that fits the plug caps I have.
- Has thanked: 85 times
- Been thanked: 687 times
I like a man who likes a challenge!
That makes the kdx i looked at look like a minter!
It turns over well enough but after a bit of hopeful faffing there's no spark. So it's check from the beginning, flywheel off and test everything from the very basics.
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
Biggest problem with these older/unloved strokers is crankcase seals. They will almost certainly be shot.
Great excuse to whip it apart for a nut and bolt rebuild. Not that you get much choice....
Plato
Plato
The plan is to get a spark, then get a bang with some spark and fuel, and then think about what to do next.
If I can't get a spark then I'll probably just sell it as spares.
