A very slow possible resurrection of an Aprilia TXR312 trials bike
Been thanked: 2730 times
It was delivered yesterday:
A quick look over the bike and the box of bits suggests it's all there. Both tyres hold air which is a start, it's easier to push about. Turning it over by hand suggests there's compression. It might need fork seals too. :D
The first thing to do is get it running. I can check for a spark by spinning it up with a cordless drill. Once that's done I'll sort the carb.
Been thanked: 15498 times
Re: A very slow possible resurrection of an Aprilia TXR trials bike 312
it might need a bit more than fork seals... I hope it was less than £20.
Been thanked: 9496 times
Re: A very slow possible resurrection of an Aprilia TXR312 trials bike
You can re-chrome the forks by rubbing them with a bit of balled up tin foil :)
MyLittleStudPony
Has thanked: 832 times
Been thanked: 586 times
Post by MyLittleStudPony »
Oh wow. Good luck with that! Although if anyone can do it, you can.
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
Thats the trouble when you buy a lathe and some workshop machinery ,you think you can repair anything.
Happy new project day.
Is it done yet? :thumbup:
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
Prillia? Never heard of that make. :think:
KungFooBob wrote: Fri Sep 20, 2024 11:28 am You can re-chrome the forks by rubbing them with a bit of balled up tin foil :)
Buy shares in Alcoa.
First problem: I haven't got a spark plug that fits the plug caps I have.
Ian
Has thanked: 1361 times
Been thanked: 578 times
Post by Ian »
Does it turn over? looks a bit rusty
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
I like a man who likes a challenge!
That makes the kdx i looked at look like a minter!
It turns over well enough but after a bit of hopeful faffing there's no spark. So it's check from the beginning, flywheel off and test everything from the very basics.
The plan is to get a spark, then get a bang with some spark and fuel, and then think about what to do next.
If I can't get a spark then I'll probably just sell it as spares.
