Electrical Question.
Has thanked: 12620 times
Been thanked: 8541 times
A lass we know runs a donkey sanctuary and money is tight.
Last week she ran over her 25m cable lead reel thingy. Nothing works now. And doesn't wind in or out.
To help, can I chop the lead where it goes into the reel and then reattach the cable to one of these? Then loop the cable by hand
Seems OK but leccy scares me.
Ta
Been thanked: 15511 times
Re: Electrical Question.
Just go buy her another one
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Post by Sadlonelygit »
Perhaps a trip to El Specsavers might be a better investment!
I was going to say something silly about water ingress to the socket.......but then I remembered where you live!
Should be fine btw!
weeksy wrote: Tue Sep 17, 2024 12:31 pm Just go buy her another one
50€. I do plenty of work there anyway.
Has thanked: 2558 times
Been thanked: 4169 times
The short answer to your question is yes, what you're planning is perfectly feasible. The sockets on the reel will be toast (as you've already discovered) but the cable should be fine. I'm not a big fan of those 'sockets on a reel' thingies - the plugs normally conspire to get in the way of each other. I'm sure it's deliberate, so you don't overload the rather puny cable those things come with.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
Not only that, if you leave the cable coiled and use it for a big load eg an electric heater, the cable can overheat and melt. Yes it happened to me......
iansoady wrote: Tue Sep 17, 2024 4:48 pm Not only that, if you leave the cable coiled and use it for a big load eg an electric heater, the cable can overheat and melt. Yes it happened to me......
Leave it in a bucket of water to prevent this happening.
iansoady
Post by iansoady »
You're the first person to make me smile today....
All done thanks.
I've given her my old 25m cable reel and I'll just keep her bodged one as a spare.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
Ideally you'd find an old or high quality multi socket which still is held together by screws rather than clips and glue, and rewire the cable into it properly.
A_morti wrote: Thu Sep 19, 2024 9:15 pm Ideally you'd find an old or high quality multi socket which still is held together by screws rather than clips and glue, and rewire the cable into it properly.
I found a proper female connector to do the job.
