Valve collets
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Valve collets
Post by Sadlonelygit »
Does this look like too large a gap to you?
And secondly, I think there's room for improvement here!
Been thanked: 14171 times
Re: Valve collets
ISTR the gap being less on a 900R,but maybe it was just more equidistant. I can't see that gap being a problem though.
Druid
Has thanked: 352 times
Been thanked: 1109 times
Re: Valve collets
Post by Druid »
looks a bit big to me. This is my GS750
Been thanked: 4529 times
Re: Valve collets
It does look a bit big, but they're not going to come out
Sadlonelygit
Re: Valve collets
Personally I think it's just Indian build quality. The exhausts were roughly the same, so I knew they had seated properly.
Pretty sure the last top end I rebuilt had a better tolerance when built.....but it's been a while!
iansoady
Has thanked: 72 times
Been thanked: 244 times
Re: Valve collets
Post by iansoady »
I always try to get the gaps on each side the same although probably no real reason - it just looks nicer.....
Has thanked: 1187 times
Been thanked: 2281 times
Re: Valve collets
You could take the spring out and seat it all with hand tension. You'd know how it looks when it's all together then.
Sadlonelygit
Re: Valve collets
Remember what I said about Indian build quality!
Looks like they got mice to make the bolt holes :wtf:
porter_jamie
Has thanked: 253 times
Been thanked: 140 times
Re: Valve collets
Post by porter_jamie »
Don't hog the exhaust out you will almost certainly make it worse unless you really know what you are doing. Do lots of reading, smokey yunick and Graham bell, before touching anything
Sadlonelygit
Re: Valve collets
porter_jamie wrote: Tue Sep 03, 2024 7:56 pm Don't hog the exhaust out you will almost certainly make it worse unless you really know what you are doing. Do lots of reading, smokey yunick and Graham bell, before touching anything
Thanks for your input, I've wielded a die grinder to good effect in the past!
Not my bike and the owner doesn't want to pay for anything he doesn't have too!
Sadlonelygit
Re: Valve collets
