Clutch replacement - friction plates only or both?
- Has thanked: 2869 times
- Been thanked: 554 times
Bike is a 2017 Ducati Scrambler Icon 800 with 13k miles on it.
The clutch is slipping under hard acceleration. Initially I thought it was down to there being not enough free-play at the lever however regardless of the free play the clutch is slipping under hard acceleration so I'm guessing the clutch is its last legs. It's also a bugger when changing down and trying to find neutral.
Never had to change a clutch before - should I change both friction plates and steel plates or should changing the friction plates be enough? Asking because I can buy just friction or both friction/steel.
- Has thanked: 10263 times
- Been thanked: 6885 times
Re: Clutch replacement - friction plates only or both?
When we were racing, we only changed the friction plates.
And we added stronger springs.
Ta. I can't imagine the steel plates have worn in 13k miles but could be wrong.
Pardon my ignorance, why add stronger springs? I assume that would require more effort at the lever? This is my missus bike FWIW - short fingers/small hands.
Hmm. Maybe. They squeeze the plates together stronger.Beancounter wrote: ↑Tue Aug 13, 2024 6:11 pmTa. I can't imagine the steel plates have worn in 13k miles but could be wrong.
But we were in our 20s.
Just try friction plates first.
I'll avoid the obvious joke
Unlike you to be so restrained.
Thanks, hadn't seen that.
- Been thanked: 4124 times
If you're having trouble changing gear it probably needs both, the steels may have warped.
Stick new springs in while you've got it apart.
How much are the plates?
LCs only ever need friction plates, the gearbox oil doesn't get got enough to affect the steel plates
It's like brake discs and pads. One set are designed to grip more, then wear out.Le_Fromage_Grande wrote: ↑Tue Aug 13, 2024 9:59 pmLCs only ever need friction plates, the gearbox oil doesn't get got enough to affect the steel plates
£103 for friction only, £189-£210 for both.Le_Fromage_Grande wrote: ↑Tue Aug 13, 2024 9:58 pm If you're having trouble changing gear it probably needs both, the steels may have warped.
Re. changing gear, it's more an issue finding neutral than anything else and is only really a problem when trying to find neutral whilst at a standstill, finding neutral whilst rolling to a stop isn't a problem. Part of me thinks it's more an issue with my missus (not a criticism, she's only been riding a few years and doesn't do that many miles.)
- Has thanked: 1295 times
- Been thanked: 872 times
Change the missus, it’ll be cheaper in the long runBeancounter wrote: ↑Wed Aug 14, 2024 11:00 am£103 for friction only, £189-£210 for both.Le_Fromage_Grande wrote: ↑Tue Aug 13, 2024 9:58 pm If you're having trouble changing gear it probably needs both, the steels may have warped.
- Has thanked: 9819 times
- Been thanked: 10144 times
I'd do the heap when I was in there,because I hate doing the same job twice.
- Been thanked: 7526 times
Sounds a bit like the clutch is dragging, you've already tried adjusting the lever, right?
Good thinking Batman. There's also sometimes some adjustment where cable is onto engine casing.KungFooBob wrote: ↑Wed Aug 14, 2024 12:46 pm Sounds a bit like the clutch is dragging, you've already tried adjusting the lever, right?
It'll be a hydraulic clutch on a Ducati.
Just need to make sure the lever isn't applying pressure to the clutch master cylinder push rod when not pulled.
If it's got aftermarket Chinese levers they sometimes do it.
- dern
- Has thanked: 1016 times
- Been thanked: 1766 times
Measure the metal plates and see if they're in spec.
- Has thanked: 3254 times
- Been thanked: 1737 times
It sounds like clutch drag to me,are you sure it's adjusted correct & if it's hydraulic is the M/C & slave cylinder working properly,does the bike try to creep frowards when it's in gear with the clutch lever pulled in?
I wouldn't be buying the clutch plates until I've measured the friction plates that are in there
Yep, well partially. Tried setting the free play at the lever and it makes no difference to the problem. Have adjusted the cable at the clutch casing end but not had a chance to ride the bike yet, hoping to do that later this evening.KungFooBob wrote: ↑Wed Aug 14, 2024 12:46 pm Sounds a bit like the clutch is dragging, you've already tried adjusting the lever, right?
Cable clutch on this one and it does have aftermarket cheap levers - those are required so the missus can comfortably use the clutch, the original levers sit too far out even on the closest setting. Haven't tried expensive aftermarket levers but happy to consider them if it helps.KungFooBob wrote: ↑Wed Aug 14, 2024 12:58 pm It'll be a hydraulic clutch on a Ducati.
I'd put the original clutch lever back on (if you have it). Then go for a ride and see if it still slips.
If it doesn't then you need to fork for some premium levers (or work out where to Dremel the cheapies).
