Clutch replacement - friction plates only or both?
Beancounter
Has thanked: 2869 times
Been thanked: 554 times
Post by Beancounter »
Bike is a 2017 Ducati Scrambler Icon 800 with 13k miles on it.
The clutch is slipping under hard acceleration. Initially I thought it was down to there being not enough free-play at the lever however regardless of the free play the clutch is slipping under hard acceleration so I'm guessing the clutch is its last legs. It's also a bugger when changing down and trying to find neutral.
Never had to change a clutch before - should I change both friction plates and steel plates or should changing the friction plates be enough? Asking because I can buy just friction or both friction/steel.
Has thanked: 10261 times
Been thanked: 6885 times
Re: Clutch replacement - friction plates only or both?
When we were racing, we only changed the friction plates.
And we added stronger springs.
Beancounter
Yorick wrote: Tue Aug 13, 2024 6:05 pm When we were racing, we only changed the friction plates.
Ta. I can't imagine the steel plates have worn in 13k miles but could be wrong.
Pardon my ignorance, why add stronger springs? I assume that would require more effort at the lever? This is my missus bike FWIW - short fingers/small hands.
Beancounter wrote: Tue Aug 13, 2024 6:11 pm
Hmm. Maybe. They squeeze the plates together stronger.
But we were in our 20s.
Just try friction plates first.
I'll avoid the obvious joke 😉
Eclipse
Has thanked: 37 times
Been thanked: 80 times
Post by Eclipse »
You might find this interesting
Beancounter
Yorick wrote: Tue Aug 13, 2024 7:14 pm
Unlike you to be so restrained. :lol:
Eclipse wrote: Tue Aug 13, 2024 7:33 pm You might find this interesting
Thanks, hadn't seen that. :thumbup:
If you're having trouble changing gear it probably needs both, the steels may have warped.
Stick new springs in while you've got it apart.
How much are the plates?
LCs only ever need friction plates, the gearbox oil doesn't get got enough to affect the steel plates
Le_Fromage_Grande wrote: Tue Aug 13, 2024 9:59 pm
It's like brake discs and pads. One set are designed to grip more, then wear out.
Beancounter
Le_Fromage_Grande wrote: Tue Aug 13, 2024 9:58 pm If you're having trouble changing gear it probably needs both, the steels may have warped.
£103 for friction only, £189-£210 for both.
Re. changing gear, it's more an issue finding neutral than anything else and is only really a problem when trying to find neutral whilst at a standstill, finding neutral whilst rolling to a stop isn't a problem. Part of me thinks it's more an issue with my missus (not a criticism, she's only been riding a few years and doesn't do that many miles.)
Gregor
Has thanked: 1295 times
Been thanked: 872 times
Post by Gregor »
Beancounter wrote: Wed Aug 14, 2024 11:00 am
Change the missus, it’ll be cheaper in the long run :P
Has thanked: 9819 times
Been thanked: 10144 times
I'd do the heap when I was in there,because I hate doing the same job twice.
Been thanked: 7526 times
Sounds a bit like the clutch is dragging, you've already tried adjusting the lever, right?
KungFooBob wrote: Wed Aug 14, 2024 12:46 pm Sounds a bit like the clutch is dragging, you've already tried adjusting the lever, right?
Good thinking Batman. There's also sometimes some adjustment where cable is onto engine casing.
It'll be a hydraulic clutch on a Ducati.
Just need to make sure the lever isn't applying pressure to the clutch master cylinder push rod when not pulled.
If it's got aftermarket Chinese levers they sometimes do it.
dern
Has thanked: 1016 times
Been thanked: 1766 times
Post by dern »
Measure the metal plates and see if they're in spec.
Has thanked: 3253 times
Been thanked: 1737 times
It sounds like clutch drag to me,are you sure it's adjusted correct & if it's hydraulic is the M/C & slave cylinder working properly,does the bike try to creep frowards when it's in gear with the clutch lever pulled in?
I wouldn't be buying the clutch plates until I've measured the friction plates that are in there
Beancounter
Yep, well partially. Tried setting the free play at the lever and it makes no difference to the problem. Have adjusted the cable at the clutch casing end but not had a chance to ride the bike yet, hoping to do that later this evening.
KungFooBob wrote: Wed Aug 14, 2024 12:58 pm It'll be a hydraulic clutch on a Ducati.
Cable clutch on this one and it does have aftermarket cheap levers - those are required so the missus can comfortably use the clutch, the original levers sit too far out even on the closest setting. Haven't tried expensive aftermarket levers but happy to consider them if it helps.
I'd put the original clutch lever back on (if you have it). Then go for a ride and see if it still slips.
If it doesn't then you need to fork for some premium levers (or work out where to Dremel the cheapies).
