Test post
For testing BB code, inserting pics, inserting videos etc.
Lutin
Has thanked: 368 times
Been thanked: 383 times
Test post
Post by Lutin »
Testing, testing.
Re: Test post
Welcome back
Lutin
Re: Test post
Post by Lutin »
weeksy wrote: Sat Aug 03, 2024 2:32 pmWelcome back
Thanks for that, but the problem still persists.
I tried the exact same reply that I'd tried that caused the problem - BitNinja page blocking access to RTTL. And got the exact same result even though I was using a VPN. I didn't think that this was possible.
Had to disconnect the VPN and restart it (with another IP address) and could then browse RTTL again.
What I don't understand is that I can find no link between by service provider and BitNinja. Also, the BitNinja page does not work properly - the link on their page to take me back to RTTL does nothing of the sort. It just attempts to connect to RTTL but times out continuously.
Very odd and very, very frustrating.
Re: Test post
You tried it with a mobile device using 4g/5g?
Lutin
Re: Test post
Post by Lutin »
weeksy wrote: Sat Aug 03, 2024 7:47 pm You tried it with a mobile device using 4g/5g?
Yes, tried that. We have a 4G mobile device. The only link is that our home broadband and the 4G dongle are with the same provider - although with separate accounts.
Has thanked: 8034 times
Been thanked: 5692 times
Re: Test post
Dunno exactly what the issue is but Lutin's current IP looks v odd
unn-149-34-242-98.datapacket.com
Not seen that unn prefix before.and it's not there on most previous posts. Is the VPN on the fritz?
Re: Test post
Bitninja issues stopping him posting. Which I believe is on the ISP end not something we can fix ?
@HiFi Kabin may know more?
Re: Test post
weeksy wrote: Sun Aug 04, 2024 7:49 am Bitninja issues stopping him posting. Which I believe is on the ISP end not something we can fix ?
Bitninja may think the IP address is iffy. I assume the VPN assigns the IP address.
Re: Test post
Going somewhere with free WiFi like a McDonald's or wherever would potentially help troubleshooting as you know it's then an ISP issue
HiFi Kabin
Been thanked: 98 times
Re: Test post
Post by HiFi Kabin »
@weeksy Its a server level 'problem' so you will have to get your hosts to whitelist this IP range (or it may be available for you to do in the cPanel)
Re: Test post
Ok, I've raised a support ticket for them to allow it.
Cheers mate
HiFi Kabin
Re: Test post
No problem
Re: Test post
Message: Hi Steve,
The IP "86.42.255.255" is currently not blocked on our server.
Please check now, thank you!
