Test post
- Has thanked: 6125 times
- Been thanked: 15488 times
Lutin
- Has thanked: 368 times
- Been thanked: 383 times
Re: Test post
Thanks for that, but the problem still persists.
I tried the exact same reply that I'd tried that caused the problem - BitNinja page blocking access to RTTL. And got the exact same result even though I was using a VPN. I didn't think that this was possible.
Had to disconnect the VPN and restart it (with another IP address) and could then browse RTTL again.
What I don't understand is that I can find no link between by service provider and BitNinja. Also, the BitNinja page does not work properly - the link on their page to take me back to RTTL does nothing of the sort. It just attempts to connect to RTTL but times out continuously.
Very odd and very, very frustrating.
Lutin
Re: Test post
Yes, tried that. We have a 4G mobile device. The only link is that our home broadband and the 4G dongle are with the same provider - although with separate accounts.
- Has thanked: 8034 times
- Been thanked: 5692 times
Re: Test post
Dunno exactly what the issue is but Lutin's current IP looks v odd
unn-149-34-242-98.datapacket.com
Not seen that unn prefix before.and it's not there on most previous posts. Is the VPN on the fritz?
Re: Test post
Bitninja issues stopping him posting. Which I believe is on the ISP end not something we can fix ?
@HiFi Kabin may know more?
Re: Test post
Bitninja may think the IP address is iffy. I assume the VPN assigns the IP address.weeksy wrote: Sun Aug 04, 2024 7:49 am Bitninja issues stopping him posting. Which I believe is on the ISP end not something we can fix ?
Re: Test post
Going somewhere with free WiFi like a McDonald's or wherever would potentially help troubleshooting as you know it's then an ISP issue
- HiFi Kabin
- Been thanked: 98 times
Re: Test post
@weeksy Its a server level 'problem' so you will have to get your hosts to whitelist this IP range (or it may be available for you to do in the cPanel)weeksy wrote: Sun Aug 04, 2024 7:49 am Bitninja issues stopping him posting. Which I believe is on the ISP end not something we can fix ?
- HiFi Kabin
Re: Test post
Message: Hi Steve,
The IP "86.42.255.255" is currently not blocked on our server.
Please check now, thank you!
