Tool purchases
Has thanked: 2556 times
Been thanked: 4167 times
Re: Tool purchases
A nine inch angle grinder and a Metabo corded die grinder are the two tools I'm actually scared to use. They can get away from you in an instant.
Sadlonelygit
Has thanked: 94 times
Been thanked: 796 times
Re: Tool purchases
Post by Sadlonelygit »
mangocrazy wrote: Wed Jul 31, 2024 3:53 pm A nine inch angle grinder and a Metabo corded die grinder are the two tools I'm actually scared to use. They can get away from you in an instant.
There's a good reason why they have a dead man switch and no throttle lock!
Been thanked: 2727 times
Re: Tool purchases
Has it got soft start? Or is it just good old fashioned on or off?
Re: Tool purchases
My 9" angle grinder is about 15 years old and doesn't have soft start - one of the reasons it makes me nervous when using it. It's also a heavy bloody thing. Are newer ones that much better? It's the torque on the Metabo die grinder that used to scare me (plus the fact I normally used it with a carbide burr). I sold it a while back and now use a much more manageable Aldi/Lidl cheapie.
Re: Tool purchases
Spindle moulders were a bit a thing too.
Sadlonelygit
Re: Tool purchases
cheb wrote: Thu Aug 01, 2024 7:22 am Has it got soft start? Or is it just good old fashioned on or off?
Off and 'awake now?'
Re: Tool purchases
Sadlonelygit wrote: Thu Aug 01, 2024 9:36 pm
Or 'Off and do I have your full attention?' :)
Has thanked: 2848 times
Been thanked: 1609 times
Re: Tool purchases
Husqvarna chainsaw - I feel like an arborist now :thumbup:
Has thanked: 10959 times
Been thanked: 3995 times
Re: Tool purchases
v8-powered wrote: Sun Aug 04, 2024 5:13 pm Husqvarna chainsaw - I feel like an arborist now :thumbup:
On first scan i read that as "abortionist", and had to re-read it....
Re: Tool purchases
I bought this today...
https://www.lidl.co.uk/p/parkside-doubl ... /p10016324
I couldn't help it for £25, it' proper tiny tho' and doesn't bolt down.
Has thanked: 1059 times
Been thanked: 1646 times
Re: Tool purchases
KungFooBob wrote: Sun Aug 04, 2024 7:01 pm I bought this today...
Drill some holes in its base?
Re: Tool purchases
demographic wrote: Sun Aug 04, 2024 7:44 pm
I could do.
Interestingly, the blurb on the webshite says it's pre-drilled, but it's not.
TBF It's so small and under powered that it's not going to fling itself off the bench.
Re: Tool purchases
It might once the wheels are worn and unbalanced.
I screw my bench grinders* to a piece of plywood and clamp them to the bench as needed.
*Wire wheel and really rough stone. Fine stone and green stone for HSS and carbide lathe tools. Double ended polisher.
Re: Tool purchases
cheb wrote: Sun Aug 04, 2024 8:46 pm It might once the wheels are worn and unbalanced.
Aye, mine kind of ambles about slowly when it's ramping up and slowing down as it hits its natural frequency but its fairly steady at full speed.
Has thanked: 1183 times
Been thanked: 2277 times
Re: Tool purchases
Any good?
Re: Tool purchases
Dunno.
I've not ground or polished anything yet :)
Seems alright, it's much smaller than your typical bench grinder. It doesn't feel like it's going to explode at full speed. The grinding wheel has a metal guard where as the polishing wheel has a plastic guard. The Flexi tool thing threw me a bit because where it attaches is reverse thread.
Has thanked: 778 times
Been thanked: 3216 times
Re: Tool purchases
dern wrote: Mon Aug 05, 2024 10:56 am Any good?
KungFooBob wrote: Mon Aug 05, 2024 11:10 am . It doesn't feel like it's going to explode at full speed.
Nah
Re: Tool purchases
A LH thread is usual on that end of a double ended grinder.
The flexi drive looks useful, I've not seen one designed in to a normal grinder before.
Has thanked: 8035 times
Been thanked: 5694 times
Re: Tool purchases
If anyone else wants a £25 bench grinder (should be £50)....I've got one and it's fine.
https://www.screwfix.com/p/titan-ttb905 ... 240v/549vv
Re: Tool purchases
I can't see why you'd need 2 grinding discs.
I changed mine many years ago to have a spinny wire brush thingy. I use it all the time.
