Porcelain Slabs
Has thanked: 484 times
Been thanked: 1427 times
Porcelain Slabs
I was asked to fix a small wall today. Its about 2' tall and topped with cut down Porcelain slabs. They have a hangover of about an ich each side and have all came loose with folk sitting on them or stepping on the wall to get to the higher section of the garden. Even the large dog jumps up on them. Can i use a silicon to stick them back down with? Was thinking of something like Sikaflex as it will keep an element of flex about it what may make it last longer.
Buy cement you twat as its a shit idea????
Has thanked: 6375 times
Been thanked: 4749 times
Re: Porcelain Slabs
Q1? Why do they have such a large overhang? That's going to add leverage if people sit/stand on the edges.
Q2? What's the underside of the slabs like? Is there anything to key onto?
(I have a similar problem with some steps. I'm seriously considering drilling and screwing as a solution! :) ).
Re: Porcelain Slabs
Count Steer wrote: Fri Jul 12, 2024 9:51 pm Q1? Why do they have such a large overhang? That's going to add leverage if people sit/stand on the edges.
Cowboy landscaper did the overhang. I would cut it off but only have a small disk for the grinder. Plus i have seen drunks walk straighter than my cutting. Even the steps going into the two patio doors have the overhang. I put facings on under them what reduces the overhand by a good1.5cm. The underside is a crisscross pattern what may be about 2mm deep.
Re: Porcelain Slabs
I thought this thread was going to be about early GSXRs
Re: Porcelain Slabs
Le_Fromage_Grande wrote: Fri Jul 12, 2024 10:16 pm I thought this thread was going to be about early GSXRs
The ugly one
Has thanked: 6187 times
Been thanked: 5087 times
Re: Porcelain Slabs
Install a Stannah for up and a slide for down :)
Re: Porcelain Slabs
Felix wrote: Fri Jul 12, 2024 10:07 pm
Hmmm. Tricky. I'd be tempted to try bathroom tile cement (or floor tile) and grout but I've no idea how it'll be with the temperature range - full sun to sub-zero. (Although the floor tiles in our conservatory seem to stay stuck down).
Been thanked: 2615 times
Re: Porcelain Slabs
I've seen CT1 recommended and used for this by people who think these things through
It's very popular, you could say it has a lot of adherents.
Has thanked: 2550 times
Been thanked: 6243 times
Re: Porcelain Slabs
cheb wrote: Sat Jul 13, 2024 9:10 am I've seen CT1 recommended and used for this by people who think these things through
Yeah but they sound like right nerds.
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Re: Porcelain Slabs
Post by Screwdriver »
Mr. Dazzle wrote: Sat Jul 13, 2024 10:22 am Yeah but they sound like right nerds.
You say that as if it's a bad thing?
CT1 no doubt about it. I just glued a brick overhang with it. Literally a brick snapped in half, overhanging a window sill.
Received wisdom tells me once in place and cured, even in exposed exterior use, it ain't goin' nowhere.
Not the sort of thing you want to get wrong! Put all the effort into alignment, spacing and level/plane. Various tricks for doing that including jigs, shim supports, even frickin lasers. You won't have any opportunity to realign it. Not ever.
Plato
Re: Porcelain Slabs
But probably better than 'Never let barely good enough be the enemy of that'll do.'
Re: Porcelain Slabs
Forgot to say. CT1 has done the job and last checked last Friday and all wall tops are still sitting solid. Some folk have still use the wall as a seat regardless of the sign saying not to but yeah, still stuck solid :thumbup:
Has thanked: 836 times
Been thanked: 1238 times
Re: Porcelain Slabs
That sounds like a challenge!
Has thanked: 15947 times
Been thanked: 10243 times
Re: Porcelain Slabs
Ct1 makes sikaflex look like sellotape...
Re: Porcelain Slabs
Taipan wrote: Wed Sep 25, 2024 4:01 pm Ct1 makes sikaflex look like sellotape...
Sikaflex was recommended to me to reseal the roof joints on a van what did the job well. However since doing this job with the CT1 it will be the tool of choice from now on :thumbup:
