Brake cleaner on chains. ???
Has thanked: 2862 times
Been thanked: 3518 times
Can we or not. ???
Been thanked: 9505 times
Re: Brake cleaner on chains. ???
Does the chain have o (or x) rings?
Been thanked: 14171 times
I wouldn't. Maybe carb cleaner,if you have to use an arsehole spray.
Paraffin for me.
Been thanked: 15511 times
Citrus degreaser. No idea if brake cleaner is appropriate.
roadster
Has thanked: 29 times
Been thanked: 214 times
Post by roadster »
I doubt that it would do any direct harm but the danger of removing all grease is that the chain will rust at the first sign of water. So a very thorough regreasing would be essential and many of the spray grease products don't penetrate very well and won't reach the places that the brake cleaner has flushed out.
Personally I have always though that cleaning chains is unnecessary unless operating off-road. When required I oil chains sparingly with very heavy duty agricultural 140 grade then leave it for a day before wiping off the excess.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
Skub wrote: Tue May 07, 2024 8:53 am I wouldn't. Maybe carb cleaner,if you have to use an arsehole spray.
Paraffin for me.
In my experience carb cleaner is more aggressive than brake cleaner (for example it dissolves wellseal). But I wouldn't use either and agree with Skub on paraffin.
Has thanked: 12620 times
Been thanked: 8541 times
Paraffin for me.
Chilled, with ice ?
roadster wrote: Tue May 07, 2024 9:06 am I doubt that it would do any direct harm but the danger of removing all grease is that the chain will rust at the first sign of water.
The danger of removing the grease is way higher than that.
The grease is what lets the rollers in a roller chain roll, without it the thing will die long before it gets a chance to rust :D
Tbh, I was thinking more push bike. Ain't the grease on motorbike chains all sealed in, not sure on pusher. Thought's were to clear grit and sandy shit then relube straight away.
Has thanked: 10971 times
Been thanked: 4004 times
Dodgy69 wrote: Tue May 07, 2024 1:55 pm Tbh, I was thinking more push bike. Ain't the grease on motorbike chains all sealed in, not sure on pusher. Thought's were to clear grit and sandy shit then relube straight away.
Probably best done with a stiff brush?
crust
Has thanked: 964 times
Been thanked: 713 times
Post by crust »
Parafin for me, pour a pint of it, into an old gallon plastic container, drop the chain in, screw lid on, shake like buggery, tip out chain and parafin into a dish and marvel at the crap thats been washed out.
Diesel / Heating oil if it's easier to hand than Paraffin, too.
wull
Has thanked: 979 times
Been thanked: 1858 times
Post by wull »
Use a dedicated chain cleaner like Motul C1
wull
Post by wull »
This is correct, they are sealed so in theory maintenance free but what you’re doing is keeping shit away which could potentially damage the seals allowing them to dry out and fail. It also keeps the chain looking good and rust free. Nothing worse than a neglected chain, when I see a chain that’s neglected I always think the rider is a lazy useless bastard.
Has thanked: 780 times
Been thanked: 3224 times
Oh, how don't miss messing about with chain cleaning n lubing :banana-wrench:
MrLongbeard wrote: Thu May 09, 2024 10:35 pm Oh, how don't miss messing about with chain cleaning n lubing :banana-wrench:
Yep...I had a belt on my Buell, with a spring tensioner, really good, only part of the bike that was reliable thinking about it. 🙃
I always thought carb and brake cleaner were the same. 🤷‍♂️
katana
Has thanked: 77 times
Been thanked: 54 times
Post by katana »
Dodgy69 wrote: Tue May 07, 2024 7:15 am Can we or not. ???
Now you have open a can of worms.
Has thanked: 5970 times
Been thanked: 3574 times
Been using WD chain cleaner for the last year as it won a couple of tests. Does a decent job. Before that I used paraffin and it works well too.
Has thanked: 20886 times
Been thanked: 13705 times
Yup WD chain cleaner for me too. I used to use paraffin but its bit of a faff getting round here now, which is a shame as i used to use it on the whole bike as even when washed off it leaves a bit of oily film.
Has thanked: 4088 times
I use parrafin to clean my pushbike chains,especially the MTB & 'Gravel bike'.They get covered in grit & it forms a grinding paste.
The road bike just gets a occasional oiling & I wipe off the excess to try & stop muck getting stuck to the chain.
