Brake cleaner on chains. ???
- Has thanked: 2862 times
- Been thanked: 3518 times
- Been thanked: 9505 times
- Been thanked: 14171 times
Re: Brake cleaner on chains. ???
I wouldn't. Maybe carb cleaner,if you have to use an arsehole spray.
Paraffin for me.
Paraffin for me.
- Has thanked: 6125 times
- Been thanked: 15511 times
I doubt that it would do any direct harm but the danger of removing all grease is that the chain will rust at the first sign of water. So a very thorough regreasing would be essential and many of the spray grease products don't penetrate very well and won't reach the places that the brake cleaner has flushed out.
Personally I have always though that cleaning chains is unnecessary unless operating off-road. When required I oil chains sparingly with very heavy duty agricultural 140 grade then leave it for a day before wiping off the excess.
In my experience carb cleaner is more aggressive than brake cleaner (for example it dissolves wellseal). But I wouldn't use either and agree with Skub on paraffin.Skub wrote: Tue May 07, 2024 8:53 am I wouldn't. Maybe carb cleaner,if you have to use an arsehole spray.
Paraffin for me.
- Has thanked: 12620 times
- Been thanked: 8541 times
The danger of removing the grease is way higher than that.roadster wrote: Tue May 07, 2024 9:06 am I doubt that it would do any direct harm but the danger of removing all grease is that the chain will rust at the first sign of water.
The grease is what lets the rollers in a roller chain roll, without it the thing will die long before it gets a chance to rust
Tbh, I was thinking more push bike. Ain't the grease on motorbike chains all sealed in, not sure on pusher. Thought's were to clear grit and sandy shit then relube straight away.
- Has thanked: 10971 times
- Been thanked: 4004 times
Probably best done with a stiff brush?Dodgy69 wrote: Tue May 07, 2024 1:55 pm Tbh, I was thinking more push bike. Ain't the grease on motorbike chains all sealed in, not sure on pusher. Thought's were to clear grit and sandy shit then relube straight away.
Parafin for me, pour a pint of it, into an old gallon plastic container, drop the chain in, screw lid on, shake like buggery, tip out chain and parafin into a dish and marvel at the crap thats been washed out.
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
- wull
- Has thanked: 979 times
- Been thanked: 1858 times
- wull
This is correct, they are sealed so in theory maintenance free but what you’re doing is keeping shit away which could potentially damage the seals allowing them to dry out and fail. It also keeps the chain looking good and rust free. Nothing worse than a neglected chain, when I see a chain that’s neglected I always think the rider is a lazy useless bastard.Dodgy69 wrote: Tue May 07, 2024 1:55 pm Tbh, I was thinking more push bike. Ain't the grease on motorbike chains all sealed in, not sure on pusher. Thought's were to clear grit and sandy shit then relube straight away.
- Has thanked: 780 times
- Been thanked: 3224 times
MrLongbeard wrote: Thu May 09, 2024 10:35 pm Oh, how don't miss messing about with chain cleaning n lubing![]()
Yep...I had a belt on my Buell, with a spring tensioner, really good, only part of the bike that was reliable thinking about it.
I always thought carb and brake cleaner were the same.
- Has thanked: 5970 times
- Been thanked: 3574 times
Been using WD chain cleaner for the last year as it won a couple of tests. Does a decent job. Before that I used paraffin and it works well too.
- Has thanked: 20886 times
- Been thanked: 13705 times
Yup WD chain cleaner for me too. I used to use paraffin but its bit of a faff getting round here now, which is a shame as i used to use it on the whole bike as even when washed off it leaves a bit of oily film.
- Has thanked: 4088 times
- Been thanked: 2513 times
I use parrafin to clean my pushbike chains,especially the MTB & 'Gravel bike'.They get covered in grit & it forms a grinding paste.Dodgy69 wrote: Tue May 07, 2024 1:55 pm Tbh, I was thinking more push bike. Ain't the grease on motorbike chains all sealed in, not sure on pusher. Thought's were to clear grit and sandy shit then relube straight away.
The road bike just gets a occasional oiling & I wipe off the excess to try & stop muck getting stuck to the chain.
