Talk to me about.....
- Has thanked: 85 times
- Been thanked: 688 times
A Kawasaki 125 b1 (I think)
Disc valve, drum front brake mid to late 60s.
It looks tidy enough (fresh paint and decent enough chrome), but will I get spares for it, when it eventually needs some!
An idea on price may be good, the gentleman has asked me to make an offer, and I have no desire to alienate him with '€50 and I'm cutting my own throat'
- Has thanked: 9825 times
- Been thanked: 10144 times
Re: Talk to me about.....
I'm not sure about the 125,but there are places such as Z-Power and Triple parts who do stuff for the disc valve twins the 250 Samurai and 350 Avenger. Ask the dude who's selling it,he'll know for sure.
Cute little bikes btw.
I can't help you there.Sadlonelygit wrote: ↑Mon Mar 04, 2024 6:13 pmHe's french, I'm limited to c'est tres belle n'est ce pas
- Been thanked: 4124 times
I assume it's a similar engine to the early KE125 I had, they're a good reliable engine but make sure the flywheel is right on the crank, mine used to break woodruff keys because it was worn, you have to take the flywheel off to change the points.
The main spares to check for are crank seals, it's probably going to need some, piston and rings should be okay as something will fit if you can't get originals.
- Has thanked: 10263 times
- Been thanked: 6885 times
laisse-moi me caresser le mentonSadlonelygit wrote: ↑Mon Mar 04, 2024 6:13 pmHe's french, I'm limited to c'est tres belle n'est ce pas
tu es un vendeur de tapis et la moto c'est de la merdeux
Is my usual response!
Well that was a smidge disappointing!
Went to have a proper gander at it today, even took the van (just in case).
You could rattle the swing arm around in the frame mounting. Backed the brakes off and it was still an effort to roll around. Steering head had a 'significant' amount of slop. Lined the wheels up, but with the amount of play at the rear, it was plus or minus 25mm.
Got around to the motor, no gearbox oil in there......mmmm.
He had no oil, I had some in the van, so offered it to him. Kick... Kick....... Kick kick kick kick for about 2 or 3 mins, nary a sputter!
Popped the carb off, dry as a bone! Checked fuel tap......full of tank sealer residue!
So now we had fuel in the carb, kicked into life and it became apparent very quickly why there was no gearbox oil in it!
So what we had was a very shiny turd!
Funniest bit was when the old geezer asked if I was interested in it!
So,it's bought then?
