Fuel pipe unclipped itself!
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
Yammie has a positive engagement QR clip on the fuel line from the tank.
Last time I took the tank off was Sept/Oct to fit the brake pipes. Done a good few hundred miles since then, but t'other day I was going out for a bimble and the bike stopped after 100yds and fuel was peeing down the side of the sprocket cover.
Had a looksee today and the clip was undone and pipe barely on.
You can't get to it without removing the tank, so not likely to be malicious, just wondered if anyone else has had an issue with such things?
Been thanked: 1228 times
Re: Fuel pipe unclipped itself!
Like these?
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
Those clips are hopeless. These are much better although need to be carefully sized.
https://www.westfieldfasteners.co.uk/Ho ... 67-7B.html
wull
Has thanked: 979 times
Been thanked: 1858 times
Post by wull »
I had it in my mind that he was talking about the QR fuel lines that are fitted like these
I assumed he was talking about some like this...
EDIT:
Wull beat me to it by 3 seconds!
wull
Post by wull »
Snap 😂
wull
Post by wull »
If it is one like Bob and I posted then have you secured it properly this time, can you pull it back off? If it’s on fine now I’d bet my bottom dollar you just hadn’t put it back on properly the last time, I’ve seen it before where they are on but not properly and take some time to come loose dependant on mileage and use of course, that could be a possibility.
Has thanked: 2556 times
Been thanked: 4167 times
Whenever I undo any QD fuel fittings like the ones wull and KFB posted, I always give the o-ring a wipe of silicone grease. The fitting goes together much more easily, there's far less chance of tearing the o-ring and suffering leaks and the grease extends the life of the o-ring dramatically.
Long or short,thick or thin,Vaseline will get it in. :thumbup:
Demannu
Post by Demannu »
Proper clip fastener. No way of accessing it other than taking the tank off, very confused.com
Gregor
Has thanked: 1756 times
Been thanked: 1153 times
Post by Gregor »
Demannu wrote: Sat Jan 13, 2024 6:01 pm th80991-22-yamaha-xsr900-gas-fuel-line-hose__50423.jpg
Similar to the one on my yamaha, pain in the arse thing, hard to get to and attaches to a flimsy plastic spigot on the fuel pump that gets me twitching every time I remove it.
There is a plastic clip that attaches over the push on fitting to prevent it seperating on mine, maybe yours is missing ?
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
When i had my BMW1000XR there were quite a few instances on the forum of bikes dumping fuel over the floor.
It was the quick release failing which caused it, some owners changed to an after market one of E Bay but i can't
remember which make.
Has thanked: 2289 times
Been thanked: 2673 times
I use these:
I use the ones with screws. They’re easy to understand.
Has thanked: 1183 times
Been thanked: 2277 times
The clip is either broken or it wasn't closed fully (easily done). If you can pull it apart when it's closed then replace it.
The only time I had one come undone was when I hadn't closed it fully.
I use these to clamp fuel hose onto barbed fittings. Far superior to jubilee worm drive clamps.
https://www.iq-parts-shop.com/en/oetike ... s-154.html
