Looks like all the extra weight makes the front tyre flat
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
- Druid
- Has thanked: 351 times
- Been thanked: 1106 times
Friends of my wife have one at the top of their stairsv8-powered wrote: Fri Dec 29, 2023 2:40 pm Not sure if we've seen this one before or not....
It will be moving as soon as the new extended garage block is built
- rodbargee
- Has thanked: 397 times
- Been thanked: 1114 times
- Contact:
- Has thanked: 2554 times
- Been thanked: 4160 times
Just wrong on so many levels...
- Has thanked: 4088 times
- Been thanked: 2513 times
That's a proper WTF
However this line in the article sounds interesting;The total weight of the bike, depending on specification, can be as low as 160 kg (352 lb), so this thing will go like a bat out of hell.
- Has thanked: 602 times
- Been thanked: 4527 times
Well it's interesting, Messcherscmit BF109s had upside down Daimler Benz engines to get the crank in the right place to drive the propeller and have the barrel of a 20mm cannon running through the crank and prop, so upside down engines work, but I think having the crank so high in the bike is going to make it handle weird.
- Has thanked: 245 times
- Been thanked: 1227 times
- Contact:
I suppose it depends what they’re purist about.Bustaspoke wrote: Fri Jan 05, 2024 3:18 pm Not one for the purist's![]()
Outside the local bike shop earlier
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
- Has thanked: 12562 times
- Been thanked: 8520 times
The Yoshimura and Showa stickers spoil it.Bustaspoke wrote: Fri Jan 05, 2024 3:18 pm Not one for the purist's![]()
- Been thanked: 2721 times
A French Bōsōzoku fan?
I like the look of the expansion chambers, very smooth.
asmethurst99
- Has thanked: 1326 times
- Been thanked: 482 times
Should be riding along behind you slowly- blipping the throttle with the clutch in with a spotty Inaka on board
asmethurst99 wrote: Fri Jan 05, 2024 6:07 pm Should be riding along behind you slowly- blipping the throttle with the clutch in with a spotty Inaka on board
IIRC you've Japanese connections, have you seen Bōsōzoku in real life?
asmethurst99
Every town has loads of wannabes so it’s difficult to tell-there is a crossover with the Yankee subculture although Bozozoku are meant to be a bush league for Yakuza but like a lot of things it’s quite opaque.
It’s a fashion as much as anything - mostly on 400’s with annoying ring ding exhausts
2 stokes command as strong a price in Japan as here so an LC is an unlikely steed of choice.
My wife is from the Boonies and Harleys are popular as are domestic cruisers .
Gregor
- Has thanked: 1755 times
- Been thanked: 1151 times
- Contact:
Tarmacsurfer
- Has thanked: 100 times
- Been thanked: 111 times
- Been thanked: 9461 times
I could go for that, but I like Bimotas.Tarmacsurfer wrote: Mon Jan 08, 2024 10:09 am I like this kit for the Monster
https://rocket-garage.blogspot.com/2020 ... WSHThdOxtA
It's just an idea at the moment basically, reading the blurb. Need someone to front the cost of actually making the tools, anyone who can do that would just buy a real Bimota?
Personally I found this equally interesting...
https://1.bp.blogspot.com/-Rgi2TUcJ3Xs/ ... 2B-018.jpg
