Has thanked: 2908 times
Been thanked: 1678 times
Demannu wrote: Fri Dec 29, 2023 12:51 pm FB_IMG_1703854235628.jpg
Looks like all the extra weight makes the front tyre flat :)
Druid
Has thanked: 351 times
Been thanked: 1106 times
Post by Druid »
v8-powered wrote: Fri Dec 29, 2023 2:40 pm Not sure if we've seen this one before or not....
Friends of my wife have one at the top of their stairs
It will be moving as soon as the new extended garage block is built
Has thanked: 2554 times
Been thanked: 4160 times
Just wrong on so many levels...
Has thanked: 4088 times
That's a proper WTF :wtf:
However this line in the article sounds interesting;The total weight of the bike, depending on specification, can be as low as 160 kg (352 lb), so this thing will go like a bat out of hell.
Been thanked: 4527 times
Well it's interesting, Messcherscmit BF109s had upside down Daimler Benz engines to get the crank in the right place to drive the propeller and have the barrel of a 20mm cannon running through the crank and prop, so upside down engines work, but I think having the crank so high in the bike is going to make it handle weird.
Not one for the purist's :D
Outside the local bike shop earlier
Been thanked: 1227 times
Bustaspoke wrote: Fri Jan 05, 2024 3:18 pm Not one for the purist's :D
I suppose it depends what they’re purist about.
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
Omg
Red hoses!
Has thanked: 12563 times
Been thanked: 8520 times
The Yoshimura and Showa stickers spoil it.
Been thanked: 2721 times
A French Bōsōzoku fan?
I like the look of the expansion chambers, very smooth.
asmethurst99
Has thanked: 1326 times
Been thanked: 482 times
Post by asmethurst99 »
Should be riding along behind you slowly- blipping the throttle with the clutch in with a spotty Inaka on board
asmethurst99 wrote: Fri Jan 05, 2024 6:07 pm Should be riding along behind you slowly- blipping the throttle with the clutch in with a spotty Inaka on board
IIRC you've Japanese connections, have you seen Bōsōzoku in real life?
asmethurst99
Every town has loads of wannabes so it’s difficult to tell-there is a crossover with the Yankee subculture although Bozozoku are meant to be a bush league for Yakuza but like a lot of things it’s quite opaque.
It’s a fashion as much as anything - mostly on 400’s with annoying ring ding exhausts
2 stokes command as strong a price in Japan as here so an LC is an unlikely steed of choice.
My wife is from the Boonies and Harleys are popular as are domestic cruisers .
Gregor
Has thanked: 1755 times
Been thanked: 1151 times
Post by Gregor »
Not that interesting, but it’s got a Gayer engine.
Hurrhurr!
Tarmacsurfer
Has thanked: 100 times
Been thanked: 111 times
Post by Tarmacsurfer »
Been thanked: 9463 times
Tarmacsurfer wrote: Mon Jan 08, 2024 10:09 am I like this kit for the Monster 👍
https://rocket-garage.blogspot.com/2020 ... WSHThdOxtA
I could go for that, but I like Bimotas.
It's just an idea at the moment basically, reading the blurb. Need someone to front the cost of actually making the tools, anyone who can do that would just buy a real Bimota?
Personally I found this equally interesting...
https://1.bp.blogspot.com/-Rgi2TUcJ3Xs/ ... 2B-018.jpg
