DefTrap wrote: Tue Dec 05, 2023 11:48 am
So what's the plan then?
A fairly flat roof with (what appears to be) a million teatowel sized tiles glued to it is always likely to fail at some point. Not enough fall, too many points of ingress.
There's about a 5 degree fall. The felt has a few cuts and nicks and a lot of the seams have damage.
My pal's advice....
Poke and prod the expensive Sikafkex rubber paint into all the damage bits and all the seams with a paintbrush.
Let it dry.
Apply the Sikafkex with a roller over the damaged areas and seams.
Then strips of Velo. It's like tissue paper.
Then soak with more Sikafkex.
Let it all dry.
Another coat of Sikafkex over treated areas.
Not sure yet, whether to paint the whole roof with the Sikafkex or just normal outside paint.
- 20231205_115059.jpg (1.03 MiB) Viewed 1174 times
- 20231205_115027.jpg (1.04 MiB) Viewed 1174 times
