shed insulation using polystyrene sheets
- formula400
- Has thanked: 482 times
- Been thanked: 1045 times
- Contact:
Re: shed insulation using polystyrene sheets
Used a little off cuts to fill the small bits
- IMG_3268.jpeg (323.41 KiB) Viewed 872 times
CBR650r
- formula400
- Contact:
Staple barrier to the studsdemographic wrote: Sun Nov 19, 2023 7:54 pm Through the vapour barrier onto the studs. So they hold the vapour barrier holds on til yer fixing the OSB on.
Oh and make sure theres something to fix the OSB to, especially on corners.
Screw roof to studs
CBR650r
- Has thanked: 8048 times
- Been thanked: 5698 times
I'd say you're a natural at this game.
- Has thanked: 1059 times
- Been thanked: 1646 times
Once the OSB is fitted to one plane is there a stud to fix it to in another?formula400 wrote: Sun Nov 19, 2023 8:14 pmStaple barrier to the studsdemographic wrote: Sun Nov 19, 2023 7:54 pm Through the vapour barrier onto the studs. So they hold the vapour barrier holds on til yer fixing the OSB on.
Screw roof to studs
You often have to put additional studs/noggins in to fix the boards to, youll work it out I'm sure.
- formula400
- Contact:
Do these board only come in 2 sizes?? 1.2x450 and 2.4x1.2
No middle ground at all
CBR650r
- formula400
- Contact:
will this stuff be ok??? its cheapish, but in the smaller size, means I go can collect it my self
https://www.selcobw.com/iko-enertherm-c ... ness=63516
CBR650r
formula400 wrote: Sun Nov 19, 2023 11:01 pm will this stuff be ok??? its cheapish, but in the smaller size, means I go can collect it my self
Yeah, that stuffs fine, just more expensive pers square metre, another option is just to cut the big sheets down to a manageble size (divisible by the stud spacing obviously) in the carpark of wherever you buy it.
Quite common for builders to break sheets/long lengths of timber especially down to more managable sizes before they go in the van, not many vans can for 4.2 lenghts of timber inside.
- formula400
- Contact:
That’s a idea, I’ve only got a focus.
Works out £22.50 a sheet
CBR650r
- formula400
- Contact:
trip to Selco done, 12 more boards collected, also got another 2 panels cut for the roof, hoping they did a better job than B&Q
CBR650r
- formula400
- Contact:
So, found a new type of blade for the jigsaw that are for soft material.
OMG….. so so much cleaner and less f@!king about.
Now I need to work out how many boards I need to do a 4.5x1.70 shed.
- IMG_4438.jpeg (544.26 KiB) Viewed 742 times
CBR650r
