Diagnosis MT'urder - MT09 won't start
twids
Has thanked: 65 times
Been thanked: 63 times
Post by twids »
Our Transit's down with electrics problems atm (again) so we only have one car (bit of a problem considering where we live) so it seemed like a good excuse to spin the MT-09 up to give me options. But oh no...
The battery is fully charged[1] but when I turn the ignition there's a very loud click coming from somewhere around the rear of the bike, possibly from under the seat.
I've read in a few places that this could be the reg/rec and is a common issue on MT's as the ignition switch can stick on.
[1] Plugged into an Optiomate most of the time
Re: Diagnosis MT'urder - MT09 won't start
Modern reg/recs dont click.
That will be the starter relay. Strike the starter with a brummagen screwdriver and try again.
Been thanked: 15492 times
Battery.
Has thanked: 8039 times
Been thanked: 5694 times
David wrote: Sun Nov 19, 2023 9:26 am Modern reg/recs dont click.
Last time I had to do such a thing I gave it a sharp tonk with a sizeable screwdriver's plastic handle. :thumbup:
weeksy wrote: Sun Nov 19, 2023 9:33 amBattery.
100%
Don't fuck about with anything else until you've tried another battery.
If you've got some jump leads try that, if it starts you know everything else is fine.
Has thanked: 2849 times
Been thanked: 1609 times
I'd be tempted to stick it in gear and rock back and forwards a few times, then try again....
Demannu
Been thanked: 1234 times
Post by Demannu »
Put an insulated handled screwdriver across the solenoid terminals and see what happens.
Does sound like a deed buttery though!
Has thanked: 4088 times
The first thing I'd do is put jump leads on it to rule out the battery.
wull
Has thanked: 979 times
Been thanked: 1858 times
Post by wull »
Put a known good battery in the equation via jump leads, or use a jump box or whatever, if it still clicks then turn your attention to the starter solenoid, you can bridge the connections so you are applying 12v directly to the starter, this takes the solenoid out of the equation, if it still doesn’t turn over then your problem will be the starter.
Demannu
Post by Demannu »
Did we ever get a diagnosis?
