I've done fork rebuilds many times in the past but that was when I had a proper garage with a work bench. Most likely I'll drop them but then get someone local to do them.ace llani wrote: Sun Oct 18, 2020 9:19 am
If it can pull dirt out, I can only imagine it will push far more in, which will then be trapped between the seal and the upper bush.
Quick fix but I'd be rebuilding them ASAP.
Will you rebuilld them yourself?
Sealmate Sealbuddy
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Re: Sealmate Sealbuddy
ace llani
- Has thanked: 36 times
- Been thanked: 45 times
- Contact:
If you can drop them out of the bike I could quote you to rebuild and post back?The Spin Doctor wrote: Sun Oct 18, 2020 12:39 pmI've done fork rebuilds many times in the past but that was when I had a proper garage with a work bench. Most likely I'll drop them but then get someone local to do them.ace llani wrote: Sun Oct 18, 2020 9:19 am
If you're interested, drop me a PM with the bike details (reg etc.)
Rich.
- Contact:
Ta. Realistically, it's going to be next year... I've already dropped a wedge of cash on a new rear shock - I'm not going to balance the books this year.ace llani wrote: Mon Oct 19, 2020 10:23 am
Rich.
ace llani
- Contact:
No problem - let m know if I can help nearer the timeThe Spin Doctor wrote: Tue Oct 20, 2020 7:00 pmTa. Realistically, it's going to be next year... I've already dropped a wedge of cash on a new rear shock - I'm not going to balance the books this year.ace llani wrote: Mon Oct 19, 2020 10:23 am
Rich.
