Kawasaki H1 1971
Has thanked: 19270 times
Been thanked: 4903 times
Re: Kawasaki H1 1971
That sounds bloody gawgus!!! :wub: :wub: :wub:
Bigjawa
Has thanked: 225 times
Been thanked: 968 times
Post by Bigjawa »
JackyJoll wrote: Sun Jul 23, 2023 4:02 pm
Bigjawa wrote: Sun Jul 23, 2023 10:24 am
Skub wrote: Thu Jul 20, 2023 1:46 pm if there were any superdooper brake shoes to be had,I'll be doing that for sure. :lol:
Get the old ones out.
Ring 028 9266 6555, ask to speak to Gerry. Only Gerry, he's the only one who knows what he's at, tell him Big Paul said to see him about relining your shoes and he'll put the best linings on them for you.
But only deal with Gerry, you'll know him because he's the spit of Josef Mengele.
These people at least sound like they know what they’re at.
https://villiersservices.co.uk/product/ ... g-service/
The number I gave is for the crowd I worked for, it's several businesses under one roof, Gerry has been relining something like 45 years, I worked with him for 13 of those years. there's nobody better.
I can reline shoes, but even though we worked in the same place, with the same tools, when it came to my own stuff, I got him to do it.
Been thanked: 14167 times
Bigjawa wrote: Sun Jul 23, 2023 10:24 am Get the old ones out.
Ta for this BJ,I'll definitely be giving him a shout at some stage. I had occasion to call on the anchors today,down a steep hill with temporary traffic lights. I thought I'd left plenty of time,but it looked for a moment that I would need to shoot the lights! An emergency stop happens veeerrry gradually even with both front and rear brakes on full.
I discovered another charming feature of the H1 today. Since this was the first motorcycle that came with CDI,it was quite hairy arsed and Kawasaki briefly went back to points ignition on some later models because the CDI interfered with folk's radios and televisions.
This was confirmed when Mrs.Skub's dab radio informs her 'no service available' when I start the bike.
*Skub,stinking up the air and the airwaves. 8-)
Been thanked: 4525 times
Skub wrote: Fri Aug 04, 2023 11:08 am I discovered another charming feature of the H1 today. Since this was the first motorcycle that came with CDI,it was quite hairy arsed and Kawasaki briefly went back to points ignition on some later models because the CDI interfered with folk's radios and televisions.
Excellent, hopefully it will jam speed camera radars
Le_Fromage_Grande wrote: Fri Aug 04, 2023 11:10 am Excellent, hopefully it will jam speed camera radars
Hold that thought. :thumbup:
I managed to bag an original 71 H1 fuel tap off evilbay and my plan is to change all the gaskets and have it internally adapted to replace 'prime' position with an 'off' position,which I'd find more useful and it'll still look stock.
H1 fuel tap.jpeg (29.62 KiB) Viewed 425 times
If you take the vacuum pipe off prime becomes the only on, but you won't have a reserve.
My main reason for wanting an off position is,the old triples are prone to leaking oil past the check valves,then filling the crankcase. I don't envisage mine sitting unstarted for long periods anyway,but I like the idea of turning off the petrol,then at least I can keep an eye on the 2T level.
Ian
Has thanked: 1334 times
Been thanked: 573 times
Post by Ian »
The petrol tap doesn't turn off the oil so it wouldn't stop oil filling the crank case. If you are really worried and want to watch for unexpected oil use A&Bs have the best oil level check - the tube down the side. You could put a cable tie around the tube and slide it to the oil level at the end of a ride, then you can see if it has dropped the next time you go out.
Weather depending,starting and riding the triple has become almost a daily affair. It's like I need my regular fix.
In other news,the Zed has been out once since I bought the H1. What's that all about?
Maybe just the newfangledness.
I'd happily look after the Zed for you :1 :1 :1 :D :D :D
Has thanked: 12466 times
Been thanked: 8460 times
Noggin wrote: Sun Aug 06, 2023 5:07 pm I'd happily look after the Zed for you :1 :1 :1 :D :D :D
God help us :obscene-birdiedoublered:
It's so good to have folk like yourself who'll happily give up their time to help a chap in need. :thumbup:
Has thanked: 2536 times
Been thanked: 4122 times
I think you need to get a good, high quality sound recording of your H1 being caned through the gears so you can re-play it during the long, wet winter nights.
And then put it up on Soundcloud or Bandcamp so we can all listen to it... :D
Skub wrote: Sun Aug 06, 2023 8:04 pm
Skub's on the pull :obscene-birdiedoublered:
Gnarly old original vacuum tap replaced with a simple on/reserve/off and the vacuum take off capped.
Early signs are good.
I have another refurbished original tap,but I can't see me putting it on any time soon.
H1 - Imgur (1).jpg (4.9 MiB) Viewed 423 times
H1 - Imgur (2).jpg (1.77 MiB) Viewed 423 times
Been thanked: 1224 times
If it’s some sort of pattern replacement tap, make sure it flows enough, because that’s very important.
Has thanked: 20617 times
Been thanked: 13507 times
He'll be alright. They only go slow on the NI summer beach run...
Chicks dig ‘em.
