Paddock stand recommendation
Has thanked: 1829 times
Been thanked: 1469 times
I bought an Oxford Premium stand , which seems to be best recommended paddock stand everywhere.
Mine is okay - using the cups it just about lifts the rear of the speedy - but not really enough to rotate the rear wheel cleanly.
On the Scrambler, it lifts the bike with a few degrees lilt to the left. The left leg appears to bend in - it's not - it is where the leg joins the handle, it rotates inwards, despite being torqued up correctly. It doesn't appear to do the same under load on the right. But you can rotate the right leg to match. So on the cups the force is being held by the drilled holes and the bolts.
If I use the track bobbins on the Scrambler, they seem to hold every in place - and it lifts as it should do.
I have arranged to send it back to Sportsbikeshop - who have said they are happy to refund.
Am I worrying too much ( and should just use the bobbins on the Scram) and should I just use it ( its a PITA to send back)
Or am I right to worry about the bike toppling over?
Anyone have any other suggestions?
Been thanked: 7536 times
Re: Paddock stand recommendation
ABBA, innit.
I have an ABBA - can be used on the old Speedy
But can't be used on the 1200 Scrambler
Is it not a matter of getting the right fittings, or is the Scrambler too high to lift the wheels if you use the swingarm pivot?
KungFooBob wrote: Thu Jun 01, 2023 9:23 pm Is it not a matter of getting the right fittings, or is the Scrambler too high to lift the wheels if you use the swingarm pivot?
It's too high ...
Quite used to the mix and match approach to fittings
Bit Heath Robinson, but could you put some blocks or something under the ABBA where it pivots to lift it up a bit?
KungFooBob wrote: Thu Jun 01, 2023 9:30 pm Bit Heath Robinson, but could you put some blocks or something under the ABBA where it pivots to lift it up a bit?
I had thought of that - in fact, I had cut some blocks ... must go and find them
Has thanked: 9835 times
Been thanked: 10148 times
If you are set on a paddock stand,I've used a Harris front and rear for years. Good quality kit,though I don't know how much they are now.
The best paddock stand I have is an old Micron one, much better than the Oxford one I also have.
Has thanked: 2407 times
Been thanked: 3636 times
Skub wrote: Thu Jun 01, 2023 9:59 pm If you are set on a paddock stand,I've used a Harris front and rear for years. Good quality kit,though I don't know how much they are now.
I have the Harris front stand that locates under (and inside) the headstock and it is without doubt the best engineered stand I've ever used. Just change the insert pin and it's been used on at least 5 different bikes I've owned.
Has thanked: 1017 times
Been thanked: 1777 times
Mr Moofo wrote: Thu Jun 01, 2023 9:15 pm I bought an Oxford Premium stand , which seems to be best recommended paddock stand everywhere.
I have the oxford premiums and don't think that much of them. Every time I use them I keep meaning to get the welder out and weld the legs to the handle because of the same issue but I never get around to it.
I would definitely use bobbins rather than cups with paddock stands though, its a lot more stable.
Has thanked: 2248 times
Been thanked: 1242 times
As per the big cheesey bloke, my favourites used to be Micron and Champion. The Champion stand I liked most because it was wider than average and kept the bike very stable
Has thanked: 2915 times
Been thanked: 2060 times
I have one of the box section ones. It's great.
https://www.sportsbikeshop.co.uk/motorc ... prod/92414
I don't the type that have the handle/legs split & bolted together in line, don't see the need unless it's for easy storage purposes.
ChrisW wrote: Fri Jun 02, 2023 11:29 am I have one of the box section ones. It's great.
That looks pretty good - if it can be used with cups as well
The split handle thing really didn’t work - allowing the two support arms to rotate in , when on cups. So stress on the bolts holding it together and an un-nerving cup angle one side
Has thanked: 1874 times
Been thanked: 2171 times
ABBA stand for my SP3. No solution for the Scrambler other than a bigger stand with adjustable arms.
Has thanked: 2945 times
Been thanked: 1883 times
Harris stand for the rear or ABBA stand for shock or front end jobs.
Mr Moofo wrote: Tue Jun 06, 2023 9:28 am
Didn't see this before replying on the other paddock stand thread - yes I'm sure you can get cups for it. I use mine for both but I made a set of cups that slip onto the other end of the square rod the hooks are on.
wull
Has thanked: 881 times
Been thanked: 1548 times
Post by wull »
As Skub I’ve used Harris front and rear paddock stands for years, I also use the Harris yoke stand.
You won’t go wrong with them, maybe more expensive than others but worth it.
The only decent pics I can find.
