Bleeding brakes
wull
Has thanked: 880 times
Been thanked: 1544 times
Re: Bleeding brakes
Post by wull »
It’s what we call reverse bleeding.
I’ve been lucky over the years as I have never really had an issue bleeding brakes both on motorbikes and cars, really lucky.
asmethurst99
Has thanked: 1042 times
Been thanked: 362 times
Re: Bleeding brakes
Post by asmethurst99 »
Did my mates KTM 990 at the weekend - manky bit of tube etc.
Still managed to get drips of brake fluid on the frame
Has thanked: 16206 times
Been thanked: 3922 times
Re: Bleeding brakes
Thank you. I have been told of this before, but would not have remembered!! And do so need to do the rear brake on the Monster when I've got it back to the garage I use in summer! Certainly need some rear brake before I take it to be checked for the certificate to get it registered - once it's registered, I can change the rear brakes for a set up I've been recommended!! LOL Need it standard for now and everyone has said - they are all that shit!! LOL LOL
Re: Bleeding brakes
I've never had any problems with a bit of pipe and a jam jar
Has thanked: 7814 times
Been thanked: 2527 times
Re: Bleeding brakes
Le_Fromage_Grande wrote: Thu Apr 27, 2023 9:00 am I've never had any problems with a bit of pipe and a jam jar
I must be of a higher class - I use a wine bottle.
:banana-wrench:
Buckaroo
Has thanked: 734 times
Been thanked: 716 times
Re: Bleeding brakes
Post by Buckaroo »
Pretty much how we recharge bike hydraulic systems: Shimano, Avid, Sram etc. Either two syringes, one on the caliper, other on the master cylinder, or just on the caliper and a small reservoir on the master cylinder. Push and pull......
wull
Re: Bleeding brakes
Post by wull »
Pretty much what I do, any container I can get my hands on really.
Has thanked: 1016 times
Been thanked: 1766 times
Re: Bleeding brakes
Works great the first time only in my experience. After that you'll have lost the syringe or broken it in the tool box by putting something heavy on it.
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Re: Bleeding brakes
Post by Bigjawa »
And don't buy a syringe from a bike place, your local vet will have one. Or amazon.
Re: Bleeding brakes
Bigjawa wrote: Thu Apr 27, 2023 10:54 am And don't buy a syringe from a bike place, your local vet will have one. Or amazon.
Go to the vet and ask for some syringes and report back :lol:
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Re: Bleeding brakes
Post by DefTrap »
I prime an empty system by sucking it through with me ol' lungs, and a long tube.
When I was younger I was dismissive of any potential health issues from this. Now I'm older I just assume the damage has already been done.
Has thanked: 1829 times
Been thanked: 1469 times
Re: Bleeding brakes
Potter wrote: Thu Apr 27, 2023 6:42 am I wasn't going to bother posting about something so trivial, but after about forty years of buggering around with bikes I've finally sussed how to fill a hydraulic brake system and I thought it might help someone.
Put it all together on the bike and orientate the bars so that the MC is level.
Put brake fluid in a big syringe.
Attach to calliper nipple with some clear flexible tube and loosen nipple.
Push brake fluid in from the calliper and watch carefully for when it reaches the MC.
Tighten nipple, top up MC as required and enjoy, no air bubbles and no mess.
It took literally less than five minutes.
The hours I've wasted bleeding brakes in the past.
I think you can buy fancy kits that draw a vacuum and pull fluid down from the MC and self bleed, but for the price of a syringe this works a treat.
I took my LC for a spin to celebrate.
I have been doing that forever. How come it took you so long ?
Bigjawa
Re: Bleeding brakes
Post by Bigjawa »
dern wrote: Thu Apr 27, 2023 11:07 am
I did, they're used for getting colostrum supplements stuff into new lambs.
Has thanked: 218 times
Been thanked: 689 times
Re: Bleeding brakes
It would be nice to have some bleeding brakes...on my mount (when it goes) the only thing the brakes do (and only the back one at that) is put the brake light on, and apply minute amounts of retardation.
Bleeding brakes? You'll be telling me next that bikes have hydraulic brakes and those shiny plate things.
Has thanked: 2550 times
Been thanked: 6244 times
Re: Bleeding brakes
I can highly recommend the ease of fitting cable brakes.
The rest of it is so so.
