The Triumph
Has thanked: 15946 times
Been thanked: 10243 times
Re: The Triumph
Amazing job mate! As the old saying goes, someone up there likes you! ;) :D
Has thanked: 10261 times
Been thanked: 6885 times
Re: The Triumph
Taipan wrote: Wed Apr 26, 2023 6:36 pm Amazing job mate! As the old saying goes, someone up there likes you! ;) :D
Friends in (very) high places ;)
A_morti
Has thanked: 310 times
Been thanked: 568 times
Re: The Triumph
Post by A_morti »
May be obvious, but get in to the gasket surfaces with a wire brush and get all the deposits away, so the new gaskets don't go the same as that old one.
Has thanked: 1874 times
Been thanked: 2170 times
Re: The Triumph
A_morti wrote: Wed Apr 26, 2023 10:27 pm May be obvious, but get in to the gasket surfaces with a wire brush and get all the deposits away, so the new gaskets don't go the same as that old one.
Yes, done that already and will do it again with a smaller brass brush I have somewhere. Just need to find it in the the disorganised mess I call the garage... wife stores all her stuff there too, so space is limited.
Has thanked: 5449 times
Been thanked: 13084 times
Re: The Triumph
the_priest wrote: Thu Apr 27, 2023 7:05 am wife stores all her stuff there too, so space is limited.
There's your mistake with the world right there. Mrs Weeksy had a deal when we bought this house "you get the house, the garden, the outside space, everything....i get the garage" nothing passes the garage door that shouldn't do so :)
Re: The Triumph
Aye well, it is no my house but belongs to the church... so the wife gets an equal share, in other words, it is all hers!
Re: The Triumph
the_priest wrote: Thu Apr 27, 2023 7:15 am Aye well, it is no my house but belongs to the church... so the wife gets an equal share, in other words, it is all hers!
Yeah, errrrm.... Still no
:twisted: :evil:
A_morti
Re: The Triumph
Post by A_morti »
weeksy wrote: Thu Apr 27, 2023 7:11 amnothing passes the garage door that shouldn't do so :)
Indeed, some space must remain sacred
Has thanked: 4359 times
Been thanked: 2850 times
Re: The Triumph
weeksy wrote: Thu Apr 27, 2023 7:22 am
:twisted: :evil:
My one remaining space was the cupboard under the stairs where my bike kit is. Came home from a full days riding last year to find she'd moved the tumble dryer in there :angry-argument:
Re: The Triumph
Radiator fan is shot. I've removed it. Radiator is in good condition, so leaving it as is. Just flushed it with clean water and hosed the fins.
Replacement is from a Sprint RS for £24 delivered. Much newer and better condition and exactly the same model number according to Triumph's part codes etc.
Buckaroo
Has thanked: 734 times
Been thanked: 716 times
Re: The Triumph
Post by Buckaroo »
I'm not a fan of this kind of work😊
Re: The Triumph
Exhaust has been given a wipe down. not going to get it perfect with 22 years of wear and tear, but it is cleaner and will fit back nicely. I was able to paint parts of the engine case with high temp paint, so that will make a difference and slow corrosion down. Going to fit the studs with some copper slip grease in a short while I think. Then I can work towards fitting the exhaust. Tank needs to come off, so that will be a bit of fun. Need to do indicator connections properly and also run a new throttle cable in, I was lazy and rerouted the old one so it would have enough length, but is does not look that tidy... Longer one allows for a better route and will also feel better being new!
Re: The Triumph
Studs and new gaskets in and exhaust back on. Easy enough to do.
Has thanked: 9819 times
Been thanked: 10144 times
Re: The Triumph
the_priest wrote: Sat Apr 29, 2023 1:03 pm Studs and new gaskets in and exhaust back on. Easy enough to do.
@Trinity765 eat your heart out. :thumbup:
Trinity765
Has thanked: 2442 times
Been thanked: 2398 times
Re: The Triumph
Post by Trinity765 »
Skub wrote: Sat Apr 29, 2023 2:15 pm
Oh. So that's what they're supposed to look like :thumbup:
Re: The Triumph
Routed in the new throttle cable. That will make a difference!
Re: The Triumph
Bike starts. Need to adjust idle a touch. Will check in TuneECU next week. Waiting on fan, then can fit radiator, fill will coolant and take for MOT.
Re: The Triumph
Going to drill out the snapped bolt using easy outs that will be delivered sometime tomorrow. I can do this on Bank Holiday Monday as I am out all day tomorrow with Priestly duties. Bike to MOT on Friday if all goes smoothly with the work. I have coolant here already and might just do an oil/filter change. Fitted new O Rings to the fuel connectors. These are E10 safe as well. I tend to run the bike on E5 only though, I do such little mileage that it really does not make much difference in cost.
Going to paint the fan shroud when it arrives so it looks better and is sealed. Will also touch up the radiator as well, just to make it pretty.
Has thanked: 1507 times
Been thanked: 1410 times
Re: The Triumph
For some reason people screw studs in tightly. There's no need to do that, just screw them in by hand. They get *torqued* when you tighten the nuts. I had some big eff off ARP 1/2in studs to replace the cylinder head bolts on my Ford 460. They got hand tightened & then the nuts got three rounds of torquing to end up at something like 180ft/lb (stock was 140ft/lb).
BTW, your *new* studs & nuts look like the 24 year old ones on my ZRX11. I sure don't miss the corrosion issues that came with living in the UK compared to the Mojave Desert. (probably posted this pic before)
Looking at the headers where they mount to the engine look like rusted/wire brushed steel, but they appear to be Stainless? How did that happen?
23 year old/104,000mile Muzzy system (bike had about 8,000 miles on it when it got Muzzified):
Has thanked: 2550 times
Been thanked: 6241 times
Re: The Triumph
Stainless can still corrode, even if it doesn't rust. Particularly when it gets really hot, like the bit of header right next to the port might...
