Zzr1100d
Has thanked: 5954 times
Been thanked: 3572 times
Re: Zzr1100d
I feel like I'm gonna real rusty when I get back on the bike, not ridden since the end of bastard October and not looking like the weather's gonna play ball for yet another week
Has thanked: 20859 times
Been thanked: 13679 times
Re: Zzr1100d
Supermofo wrote: Sat Apr 01, 2023 10:02 am I feel like I'm gonna real rusty when I get back on the bike, not ridden since the end of bastard October and not looking like the weather's gonna play ball for yet another week
I feel like that after being off on holiday for a couple of weeks. Takes a while to sharpen up your reactions again...
Ssray
Has thanked: 209 times
Been thanked: 214 times
Re: Zzr1100d
Post by Ssray »
We had a 'gang' of peeps trying to steal my bike last night, I was in long, Tammy rang me, she was in bed and loud bangs outside, opened the ensuite with the light on, there were between 6-8 of them in masks.
I called the police who did a local check and came and saw Tammy was ok.
The lock held up so it's still here, new lock on it now, can't put it in the garage I'd have to move the car each time and I'd rather they took it than get into the garage
I've ordered a security WiFi light thing, it records and I can view it live and shout through it.
The zzr needs a new front wheel, it's not heavily damaged but it's bashed right at the bead and one sisc is bent, a bit of bodywork damage but not worth the insurance company getting
Re: Zzr1100d
Ssray wrote: Thu Apr 27, 2023 8:05 am We had a 'gang' of peeps trying to steal my bike last night, I was in long, Tammy rang me, she was in bed and loud bangs outside, opened the ensuite with the light on, there were between 6-8 of them in masks.
Cunts. That's not what you need any time.
Re: Zzr1100d
Makes my blood boil that these wankers go around taking people's tsuff they've worked to get. :x Bunch of no-hopers. Its all they'll ever be. :roll:
Has thanked: 2290 times
Been thanked: 2675 times
Re: Zzr1100d
Ssray wrote: Thu Apr 27, 2023 8:05 am can't put it in the garage I'd have to move the car each time and I'd rather they took it than get into the garage
Put it inside the house...
Ssray
Re: Zzr1100d
Post by Ssray »
The problem is that Richard won't even fit in the house let alone the bike, Richard is the one without the hat
Ssray
Re: Zzr1100d
Post by Ssray »
It's back on two wheels
Currently sporting a zrx1200 front with zx12r discs
Fit's straight on, the rear is being a pain, different bolt pattern for the rear disc, it will have to wait
Felt very nice on a short test ride today, maybe one of the Harrison 6 pots needs a quick clean
Ssray
Re: Zzr1100d
Post by Ssray »
Red rear to follow
Ssray
Re: Zzr1100d
Post by Ssray »
The poxy rear wheel won't fit, different disc(which I bought) hugely different cushdrive set-up, I don't have the time or dosh to be messing around like that, so I'm looking for a plug and play version, seems some zx7/9's maybe but no concrete evidence on the net
Re: Zzr1100d
Ssray wrote: Wed Jun 14, 2023 8:37 am The poxy rear wheel won't fit, different disc(which I bought) hugely different cushdrive set-up, I don't have the time or dosh to be messing around like that, so I'm looking for a plug and play version, seems some zx7/9's maybe but no concrete evidence on the net
Damn, thats annoying!! Normally the dedicated forums have the answers to these type questions. Is there a zzr1100 forum?
Scotsrich
Has thanked: 92 times
Been thanked: 820 times
Re: Zzr1100d
Post by Scotsrich »
Taipan wrote: Wed Jun 14, 2023 9:53 am
Used to be a ZZR international forum but I think that’s gone now. It used to be a mine of information when I had my ZZR’s and wheel swapping was one of the topics I remember being discussed regularly.
From what I remember ZX9’s were the preferred choice.
Facebook may be your only option now.
Re: Zzr1100d
There are several ZZR1100 closed groups on FB.
https://www.facebook.com/groups/1427564677549055
Re: Zzr1100d
Re: Zzr1100d
FFS, was reading through this thread again & notice that I said I was gonna flip the eccentrics back in bloody February. Maybe I should get around to that. It's due an oil & filter change, plus I need to pop the clutch cover off & fit the Compton alt/starter chain tensioner mod doodad. I can do that while the oil is out of it.
Ssray
Re: Zzr1100d
Post by Ssray »
Thanks, I'm a member of all of those,plus a few more, I'm thinking of looking up the cush drive rubbers part number and see what else they fit, then I should be able to get the correct sprocket carrier, the zrx12 wheel may still fit.
Re: Zzr1100d
Ssray wrote: Thu Jun 15, 2023 6:24 pm I'm thinking of looking up the cush drive rubbers part number and see what else they fit, then I should be able to get the correct sprocket carrier, the zrx12 wheel may still fit.
I know people fit ZX11 wheels to ZRX's so it should be doable.
Ssray
Re: Zzr1100d
Post by Ssray »
I've removed the rear wheel from evilbay, I'm going to look at getting a sprocket carrier etc.
Mot up at the end of the month, so it's going to have to wait a bit
Ssray
Re: Zzr1100d
Post by Ssray »
The MOT is up as of last Friday, so I thought I'd do some jobs on her and also this month I'm having to do a load of work on the family car(brakes,tyres and new Aircon condenser, hopefully fitting next week end)
So I've found the l/h frame spar has a dent, the tank lines up correctly,so I'm thinking it's a dent rather than a bend
So ... Do I reframe it? just use it as it is ? If I keep it I'm probably going to get a used 4 into 1 as the std exhaust weighs about 20lbs per side.
The brakes have never inspired confidence, even with the r1m master cylinder, I've used a few calculators online but I'm not sure £309+ is the way to go.
Re: Zzr1100d
Dented frames are fairy common, how bad is it?
