Zzr1100d
Ssray
Has thanked: 209 times
Been thanked: 214 times
Re: Zzr1100d
Post by Ssray »
ZRX61 wrote: Fri Feb 24, 2023 10:35 pm Just thought of something:
Front brake feel & bite etc... Play with the span adjuster. I thought there was something wrong with the front anchors on mine, then I increased the span & they were much improved. They still aren't like my ZRX fronts which will howl the front tire with maybe 1/2in of lever travel, but they get the job done.
I did that,but still thought they were not up to spec, the radial master cylinder is soooo much better
I think I've just got luck with the piston size
Ssray
Re: Zzr1100d
Post by Ssray »
It's been sitting since the (I thought) clutch slave cylinder fails, rebuilt it and..... Couldn't bleed it, bought a vacuum bleeder, still no good, slave off again, the seal was the right way round.
Bleed nipple as I was getting a load of air out of it but no pressure at the lever.
I found out that the clutch hose is rubber then attached to metal, it had split just above the join.
The stainless one arrived today,may fit it tomorrow
Ssray
Re: Zzr1100d
Post by Ssray »
All bled up etc, started it up and ....no drive
I held the front brakes on and put it into gear and let the clutch lever out and nothing, not even a noise from the clutch area.
At least with the stainless hose I can remove the slave cylinder and see how it's working
Lots of feel at the lever
MyLittleStudPony
Has thanked: 831 times
Been thanked: 586 times
Re: Zzr1100d
Post by MyLittleStudPony »
Could you just pop the whole thing in the bin?
Ssray
Re: Zzr1100d
Post by Ssray »
MyLittleStudPony wrote: Sun Mar 19, 2023 12:15 pm Could you just pop the whole thing in the bin?
It's very tempting, thinking of getting it sorted and getting a early vfr750 instead, I would have to fit CBR wheels though
Ssray
Re: Zzr1100d
Post by Ssray »
Clutch master cylinder rebuilt twice yesterday, the first time I used the new spring from the kit but it was a bit shorter then to oe one, the lever had not a lot of travel until it hit the bar, so I redid it with the old one spring
Much better, the lever has resistance from further away now
Not made sure that the clutch engagers correctly yet as Tuesday it's carbs off as it's still crap at starting Even after taking them to bits the other day, I have brand new pilot jets to go in and I'm going to I attempt to at least fit the bottom half of the carbs in the ultrasonic cleaner
It starts on 3(?) No1 is cold enough to touch when no 2,3or4 will burn skin off
Ssray
Re: Zzr1100d
Post by Ssray »
I lied, no 4 is cold too,I just tried it, I couldn't get to the other side before
So it starts (kind of for 1 second) on 2 cylinders
Should I get gpz500 badges??
Re: Zzr1100d
1 and 4 cold might suggest a coil?
Has thanked: 20859 times
Been thanked: 13679 times
Re: Zzr1100d
Skub wrote: Sun Mar 26, 2023 5:48 pm 1 and 4 cold might suggest a coil?
What do 2 and 3 think? :think:
Ssray
Re: Zzr1100d
Post by Ssray »
I swapped the coils over, 2 and 3 getting warm but not 1 and 4
I also chopped a bit from each end of the plug leads just incase there was any corrosion.
As the airbox was off ,I used a bit of easy start into the non running carbs, still no better
Re: Zzr1100d
Check there is power going to the coil serving 1 and 4,same as 2 and 3.
It could be the pickup coils on the electronic ignition,but check for dirty/bad connections along the way before you replace anything.
Ssray
Re: Zzr1100d
Post by Ssray »
I've got 11.38 volts constantly at one coil (1+4) on the loom side and nothing at the other coil(2+3)
1+4 are the non running cylinders
Ssray
Re: Zzr1100d
Post by Ssray »
She runs and so far runs really well.
Today as it was a day off,I removed the carbs again, fitted the new pilot jets , sprayed everything, every passage I could get to, poked a single strand of wire in every little hole I could see.
Stripped and cleaned the throttle housing.
I set up a aux tank(small funnel stuck into the fuel line, topped up from a jamjar (it works)
As soon as fuel disappeared from the funnel (on took a second to empty) I stopped her turning over and topped it up, then it ran, so much better than ever, tomorrow new fuel filter and go for a ride
Re: Zzr1100d
Fingers crossed for teh road test. :thumbup:
Has thanked: 2290 times
Been thanked: 2675 times
Re: Zzr1100d
Ssray wrote: Tue Mar 28, 2023 2:22 pm She runs and so far runs really well.
What flavour?
Ssray
Re: Zzr1100d
Post by Ssray »
What flavour?
[/quote]
Strawberry of course, don't believe you had to ask
Ssray
Re: Zzr1100d
Post by Ssray »
Sodding clutch won't engage now, I've rebuilt the master and slave cylinders, piddling down outside, probably a good thing
Ssray
Re: Zzr1100d
Post by Ssray »
Road test done, it starts, the clutch works,, it's just the rider is a bit rusty
Re: Zzr1100d
Ssray wrote: Thu Mar 30, 2023 2:02 pm Road test done, it starts, the clutch works,, it's just the rider is a bit rusty
Nice one! What was the clutch issue?
Ssray
Re: Zzr1100d
Post by Ssray »
Taipan wrote: Thu Mar 30, 2023 4:14 pm
Someone who's a bit rusty had put the piston in the wrong way round, I managed to download the workshop manual and after a 0345 shift I managed to see what I had done wrong
