Murphy door / overlapping door / kind of sliding door…
Has thanked: 316 times
Been thanked: 1078 times
Post by Silly Car »
My google foo is failing me here and I’ve run out of search terms to try and find what I’m looking for…
I saw a TikTok / instagram / Facebook short where a joiner had devised a “hinge” mechanism which allowed a bookcase door within a row of bookcases to open like a normal door then fold back in front of the adjoining bookcase much in the same way a sliding door on a car / van but without the tracks just operating off hinges.
I probably haven’t explained myself very well but hopefully the below will kinda help:
Fingers crossed someone can find the short video clip / find something similar / etc
Has thanked: 781 times
Been thanked: 1072 times
Re: Murphy door / overlapping door / kind of sliding door…
The hinge would need to be above the book cases and pivot half way* along the left hand case to make that work.
* Variable depending on how far back it is attached to each.
Has thanked: 780 times
Been thanked: 3224 times
Post by Silly Car »
Mussels wrote: Wed Mar 15, 2023 8:52 pm The hinge would need to be above the book cases and pivot half way* along the left hand case to make that work.
I completely understand where you are coming from but in this missing clip, the hinge appeared to be mounted on the side of each bookcase rather than the top.
MrLongbeard wrote: Wed Mar 15, 2023 8:53 pm
I found that video and it is the closest to what I previously found, and would work in the space so thanks for linking it.
Post by Silly Car »
[media] [/media]
I finally found the video clip.
Has thanked: 10971 times
Been thanked: 4004 times
There's a third piece of wood in that list video. So you have 2 sets of hinges, either side of a "filler" that will be the half the width as your desired "offset" from the original position (or, more likely, the same width as the depth of the "door")
(Or something)
Post by Silly Car »
I have managed to draw it up in sketchup whilst wasting the last afternoon at current employer’s expense, I’ll upload a picture of it later, but essentially RB has got it nailed.
L shaped piece which offsets for depth and width of moving bookcase with hinge at either end.
A ‘packer’ on the side of fixed bookcase and another on the back of the moving bookcase to account for thickness of the L shaped piece
I’m pretty sure the entire mechanism could be fabricated out of steel for added strength/ reduced thickness which may work better than just using wood.
Post by Silly Car »
I haven't got a clue how to animate within Sketchup 2017 but hopefully the attached images make sense, there is an alignment issue I need to resolve as part of the L shaped piece gets embedded into the sidewall.
