S1000RR Sport 2022
wull
Has thanked: 880 times
Been thanked: 1544 times
Re: S1000RR Sport 2022
Post by wull »
Skub wrote: Mon Dec 12, 2022 9:57 am I was disappointed not to see 190. :cry:
At the time I wasn’t watching the speedo but the app said 190 top speed reached, then watching the footage back it got to 189 and that was it, the app is clearly a big lying cunt of a bastard 😂
Has thanked: 9827 times
Been thanked: 10145 times
:lol:
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
wull wrote: Mon Dec 12, 2022 5:18 am
Bigyin wrote: Sun Dec 11, 2022 10:35 pm The onboard video always makes me laugh ... am i right in thinking the 187 stretch is the newer crossing at Kincardine
Yeah the Clackmannan Bridge.
Thought I recognised it as my aunt lives near there, Police Scotland training college at Tulliallan is just up the road as well so watch out for baby traffic cops out learning ;)
wull
Post by wull »
Bigyin wrote: Mon Dec 12, 2022 4:25 pm
Yeah I see them often.
wull wrote: Mon Dec 12, 2022 4:35 pm
Very briefly,I'd imagine. :lol:
Has thanked: 4360 times
Been thanked: 2851 times
wull wrote: Mon Dec 12, 2022 10:48 am
Take it back the bike is clearly not fast enough, bloody Germans :thumbdown: :angry-cussingblack:
Has thanked: 1746 times
Been thanked: 2085 times
Those Scottish autobahns, wish we had them. 😄
wull
Post by wull »
Something I had added to my “wanted” list was the 2D Potentiometer sensor for the front suspension, this allows you to adjust the front compression and rebound independent of each other as oppose to the current standard set up which is the one adjustment that does both.
It’s not ideal but it was good enough, but I wanted that little extra adjustment that was more accurate to what I wanted, being able to fine tune it more. I wanted this more for track days, one came up for sale second hand and I couldn’t resist.
It comes with the fitting kit but what I’ll have to purchase is bump stops as the sensor will foul the radiator without them.
I’ll get some pics when I fit the sensor along with the before and after with regards the adjustability on the dash.
wull
Post by wull »
The bump stops have arrived, so I can now fit the sensor when I have the time. Another issue because it has the standard road fairings is the inner piece at the radiator, the radiator shroud or whatever it is that they call it. The sensor will foul that apparently so x amount of material will have to removed from it.
What I will do is fit the sensor along with the bump stops, then refit the fairings to see exactly where it touches this piece if it does at all, if it does I can then workout exactly where i need to shave material from and roughly how much. What I might do is purchase one second hand so I can keep the original one good, to be fair you can’t see it without looking down the fork leg but because I’m OCD as fuck with this sort of shit I’d rather mess around with another and keep the regional perfect.
wull
Post by wull »
I finally made a start on fitting the 2D potentiometer.
Parts to fit
Bump stops to reduce steering so sensor clears radiator. Sensor fitting kit and sensor itself.
Here is pics of the dash suspension settings before fitting the sensor. The top picture shows the settings when you select race configuration, so at a glance you can see what your settings are for each race pro setting, notice the DDC settings for the front have only one adjustment whereas the rear has two adjustments. The second picture is when you select one of the race pro modes for adjusting and the third is when I’ve selected to adjust the DDC, showing clearly one adjustment for the front and the usual compression and rebound adjustment on the rear.
First job was to remove the fairings including radiator shroud, always fun on the S1000RR, plenty creaking and almost like cracking when you unclip plastic fasteners
Once removed I was able to fit the bump stops, they were a pain in the arse to fit because of limited access but I got there in the end up, a little bit of loctite added just to be on the safe side but they come with a nyloc nut.
For fitting the sensor mount kit you have to remove the bolt that secures the wheel sensor, the mount fits over the backside of the sensor with the longer bolt that’s supplied. Then you fit the bolt with the 6mm ball joints which the sensor attaches to. On the lower fork clamp you remove the upper bolt and replace it with the bolt that’s supplied which accepts another 6mm ball joint for attaching the other end of the sensor.
Sensor fitted showing where it’s mounted, you can see it just clears the radiator with the bump stops in place
The after showing the adjustable front compression and rebound independent of each other.
Only job left to do is remove some material from the radiator shroud as it fouls that apparently, what I’ll do is put the fairings and shroud back on to see exactly where it fouls if it does then work out how much I’ll have to remove.
Trick. 8-)
wull
Post by wull »
I stuck the fairings back on to check for clearance, and sure enough it fouls the radiator shroud, just, I mean the smallest amounts.
A few pics showing the clearance or lack of, on the way from lock to lock
So I’ve taken the fairings back off and marked the amount that I’ll take off, roughly 5mm which should be more than enough.
I was going to purchase another shroud to keep this one as is but for all it is I’ll just use this one, you can barely see it and have to look right down by the fork to see it. I won’t lose any sleep over it, maybe 👀🤦‍♂️
wull
Post by wull »
I removed the area that I had marked and stuck everything back on. I wasn’t happy, it was fine everywhere except for one little bit where it was far too close for my liking, it didn’t touch but the gap was tiny and depending on what angle you were looking at it was ridiculously small.
But was fine elsewhere
So I only had to concentrate on the bit that was very close. So off with everything again, take some more material off then back together to be rechecked.
I’m happy with that, won’t foul anything.
Has thanked: 5451 times
Been thanked: 13087 times
wull wrote: Tue Dec 13, 2022 7:12 pm Something I had added to my “wanted” list was the 2D Potentiometer sensor for the front suspension, this allows you to adjust the front compression and rebound independent of each other as oppose to the current standard set up which is the one adjustment that does both.
Wow... that's very very trick !
wull
Post by wull »
Is it spring time yet? Can’t come quick enough. Fairings back on now after fitting the 2D potentiometer.
Bike is ready to go now, not got anything to do except maybe purchase the quick release fuel cap so not the full unit just a replacement cap which isn’t too expensive. I need a set of tyres mind you which I’ll get soon enough, I’ll probably go with the same, I’m looking forward to having a play with the suspension settings especially now the front rebound and compression are independent to each other.
I’ve been thinking about a full exhaust system, I was originally not wanting one, a slip on at the most but recently I’ve changed my mind, so that’s something to consider.
Right now, looking outside at the frost... it seems a long long way from spring. I'd expect up there in the wastelands, it's even less spring like.
Yup bloody cold down here. Spring feels at least 2 months off :( I SORN the bike the other day as no point paying for tax whilst it's in the garage.
wull
Post by wull »
-6 this morning, light dusting of snow the other day which is taking its time to shift at work. One extreme to another.
Lying snow here for the past few days. On the warmer days it hits a high of 4°c. Sitting at 1° atm.
I haven't managed to make it out for the paper yet.
It's only 5 weeks until the WSBK season start in Oz.
wull
Post by wull »
Weapon of choice for work this morning. The wife needed the car and refused to get up early and take me to work, so I had to tax the bike and use it today. Thankfully it’s not overly cold today but I still made use of the heated grips.
