Type 2 EV connector shroud - Make or buy?
Kneerly Down
Has thanked: 135 times
Been thanked: 254 times
Post by Kneerly Down »
The Type 2 connector on my son's EV charging station has been damaged.
I imagine getting an entire new plug is going to be pretty expensive...these are rated at 63A whereas the only readily available ones seem to be max 32A,
The damage seems just to be to the shroud, that looks like it's probably a separate moulding but I can't see anywhere that sells them separately.
Wondered if getting one 3D printed would be possible/sensible or if a shroud from a lower amperage plug would work...type 2 shrouds should all be compatible as it's a standard size irrespective?
Has thanked: 717 times
Been thanked: 2045 times
Re: Type 2 EV connector shroud - Make or buy?
153 quid if i am looking at the right one. How much is a 3d printer then time wiring it all together?
Kneerly Down
Haven't seen the right one for sale yet. Do you have a link for the £153 one?
Thanks
Sorry mate forgot to come back to this.
https://www.cef.co.uk/catalogue/product ... ?gclsrc=ds
Then local to me this came up but i based that in looks rather than spec. If its the one do a deal and if needed ill go fetch it and post up if you want
https://www.facebook.com/marketplace/it ... 970941236/
Aaand scrap both. Re read your post with less red wine and see you want 63A not 32 :D Sorry
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Post by Demannu »
https://www.ev-chargingcables.com/sale- ... -plug.html
Ok it's in China, but it is what you want.
Looks like the 32a is 220v, but the 63a is 415v feed.
Kneerly Down
Thanks.
Yep. 3 phase so 415V or thereabouts.
I've ordered a 32A 3ph plug in the end.
The plugs contain a resistor in them that indicates the maximum charge rate that the cable/plug can deliver so should be okay and nearly all the AC type 2 cars don't seem capable of taking higher current anyway. It'll still be the fastest Type 2 for around 20 miles! ;)
There's an eBay seller in Germany who's selling the 63A plug you linked to so might change to that later.
Couchy
Has thanked: 361 times
Been thanked: 2246 times
Post by Couchy »
AC is a max of 32A 3 phase, I’ll have a look at work I’ve got around 40 disused charge points in the yard not sure if any are tethered but I’ll find out 👍
Kneerly Down
Couchy wrote: Sat Dec 10, 2022 8:59 pm AC is a max of 32A 3 phase
AC Fast chargers are max 32A 3 phase.
The 43kW Type 2 AC 'rapid' chargers are 3 phase 63A.
Couchy
Post by Couchy »
Kneerly Down wrote: Sun Dec 11, 2022 10:00 pm
Are you in Europe ? The 43kw are for 380v 3 phase which is a European voltage, I’d assumed you were in the UK where we have 7/11/22kw for AC and then 25- for DC. 😁
As far as I’m aware only the Renault Zoe has an onboard 43kw charger or did. There were a few charge points in the UK but they aren’t installed anymore.
Kneerly Down
Couchy wrote: Mon Dec 12, 2022 8:03 am Are you in Europe ? The 43kw are for 380v 3 phase which is a European voltage, I’d assumed you were in the UK where we have 7/11/22kw for AC and then 25- for DC. 😁
Sorry, my mistake...it's 44kW not 43kW ;) (although the plug spec is 43kW)
Screenshot 2022-12-12 160829.jpg (65.39 KiB) Viewed 531 times
Couchy
Post by Couchy »
Yeah it's the same thing and a hangover from when that size AC was an option and it isn't anymore, had a look at work and non are tethered so no connectors on them, have you managed to source one ?
Kneerly Down
Hoping something will arrive soon. :)
Has thanked: 781 times
Been thanked: 1072 times
No wonder there are so many broken around the country if they are all a faff to repair like this.
Has thanked: 19612 times
Been thanked: 4960 times
Kneerly Down wrote: Sat Dec 10, 2022 7:05 pm
If that's a faff to get to the UK, you can send it to me and I'll forward it on
Kneerly Down
Noggin wrote: Mon Dec 12, 2022 6:43 pm If that's a faff to get to the UK, you can send it to me and I'll forward it on
Should be okay.
Could send it to the chalet in Morzine...6 days to go! :D
Not sure what my boots will be like...they've been in the unheated ski locker room since before lockdown 1.
Kneerly Down wrote: Mon Dec 12, 2022 8:13 pm
Should be okay.
Awesome :D Boots should be ok. Cross fingers!
