Project Aprilia
Has thanked: 1183 times
Been thanked: 2277 times
Re: Project Aprilia
Dodgy knees wrote: Wed Nov 09, 2022 6:12 pm I'm sure my single ncb covers all bikes. 🤷🏻‍♂️
If you have a single policy covering all the bikes then that's the case but you can't use a single NCB on multiple policies. When I've set up policies recently they explicitly ask if I'm using the NCB on any other policy.
Been thanked: 15493 times
Re: Project Aprilia
dern wrote: Wed Nov 09, 2022 6:29 pm
Is the correct answer. Each separate policy requires its own.
Been thanked: 3505 times
Re: Project Aprilia
Multi bike policy, one policy.
Re: Project Aprilia
I thought about doing that but I'm not convinced it's what I want to do.
Re: Project Aprilia
Re: Project Aprilia
That's completely different. That's a multi bike policy
Re: Project Aprilia
MOT passed. Onwards!
Re: Project Aprilia
Sorted out the insurance and tax as I really wanted to take it out. Was a bit grim today with some slippery roads but mostly it was ok.
Came up nice with some muc-off and a jet wash though.
Bad points...
- Odd little occasional knock from the front end. Suspension has just been serviced and bike has been mot so could be pad/disc movement so will check that out and strip the front end to fix whatever is needed.
- Big hesitation with wide open throttle application. Light throttle is fine but big applications cause it to bog down for half a second, launch forward and hesitate again. Bit sketchy with the roads as they are but was completely rideable and will start looking at this issue when I get time. Will start with plugs and move through the electrics and fuel. Fuel that was in it hasn't been in there for an excessive amount of time and I mixed it with new super before riding it. Could be a partially blocked injector though I guess. Will find the issue.
- Clutch is so so so heavy. Will work out with my left hand.
- Horn is where the indicator switch should be which is irritating.
- The mirrors are shit
Good points...
- Sounds awesome
- Suspension is ace given how crap the roads are, very confidence inspiring. Hit a big lump of shite on the road that was at least 6 inches tall. Was following a car and couldn't avoid it at the time. Must have deformed the muddy lump quite a bit but the suspension just soaked it up amazingly. Rear suspension is hard but fine.
- Steering initially feels heavy but after ten minutes feels brilliantly stable.
- It's not that uncomfortable... it's not sit up bike comfy but it's ok.
- It looks the bollocks and felt really special to ride.
- The engine (misfire aside) feels just lovely
- Gearbox is excellent
- The throttle response is superb, just refreshingly perfect after the KTM
So there you go, work to do but I love it. KTM will be up for sale in due course.
Re: Project Aprilia
Looks very nice Mark, will it see the track. ?
Re: Project Aprilia
Dodgy69 wrote: Sat Nov 26, 2022 6:36 pm Looks very nice Mark, will it see the track. ?
Very unlikely. Happy enough with the track bikes.
Re: Project Aprilia
Ordered an oberon clutch slave as this one was leaking and was 'fixed' before I collected it. Definitely possible that it was fixed with some goop so will have a really good clean out of the actuating rod and tunnel, fit a new slave cylinder and that should make the clutch better. Also ordered new sparks plugs and air filter as a starting point for sorting out the hesitation issue. Will also balance the throttle bodies.
Has thanked: 2556 times
Been thanked: 4167 times
Re: Project Aprilia
dern wrote: Sat Nov 26, 2022 7:05 pm Ordered an oberon clutch slave as this one was leaking and was 'fixed' before I collected it. Definitely possible that it was fixed with some goop so will have a really good clean out of the actuating rod and tunnel, fit a new slave cylinder and that should make the clutch better. Also ordered new sparks plugs and air filter as a starting point for sorting out the hesitation issue. Will also balance the throttle bodies.
Oberon slave is a good move. It does make the clutch somewhat easier to operate, but it's still quite a heavy action. OE slaves had a reputation for being leaky. Sounds like you're steadily working through the weak points and issues.
Re: Project Aprilia
V-twins in (next to) da house.
Never used to like v-twins, funny how things pan out.
Re: Project Aprilia
So it's just the 1290SDR getting sold mate ?
Re: Project Aprilia
Yes at the moment.
Re: Project Aprilia
Have it... 👆
Re: Project Aprilia
Also why does the aprilia sound awesome and yet the KTMs sound like a box of kettles kicked upstairs?
Has thanked: 20859 times
Been thanked: 13679 times
Re: Project Aprilia
That's knocked the bollox out of my MT-09 and SH300 picture! :hmmm:
:lol:
Re: Project Aprilia
Potter wrote: Mon Nov 28, 2022 10:00 am The factory RSV I had is still (in my mind) the fastest bike I've ever ridden, I've since ridden more powerful bikes but the raw visceral feeling of speed on that thing was hair raising. When I first got it I took it out on a long straight road that is quite narrow and gave it full throttle, the road seemed to narrow and converged into a point that looked like it was a foot off the front wheel, I had to slow down and get a grip of my senses, I'd never experienced that before.
When i rode the 1199 I got that.... It was still the most remarkably scary thing i've ridden
Has thanked: 2849 times
Been thanked: 1609 times
Re: Project Aprilia
If you can find one, try and get one of the open airbox kits - give loads more air box volume (capacity and induction noise!).
Perhaps get it to someone that has the AxOne kit to check which map is loaded (unless it has a Power Commander?) - a lot of people fit Akra's etc but don't bother switching to the 2nd map loaded in the ECU
