Was that the before or after?dern wrote: Fri Nov 04, 2022 4:29 pm Started to tidy up the garage to get the aprilia in. In the current state I can’t get all the bikes that were in there in. I’m sure it’ll be ok in the end.
Project Aprilia
- Has thanked: 6125 times
- Been thanked: 15493 times
Re: Project Aprilia
- dern
- Has thanked: 1183 times
- Been thanked: 2277 times
- Has thanked: 2852 times
- Been thanked: 3505 times
- dern
- dern
Re: Project Aprilia
Picked it up this morning...
Needs a really good clean to have a proper look but bad points...
- Dash plastic is slightly scratched but looks like it'll polish out
- Paint on tank has bubbled so I'll drain it and let it dry and see where we are. It's a plastic tank so not unexpected, may need paint
- Pillion seat has some wear on corners so will need recovering or replacing with a plastic cover
- Needs an mot, booked in on Thursday
Good points...
- All the mechanicals are extremely clean for its age
- Started easily and sounds awesome
- Receipt for linkage plates
- Receipt for ohlins service/rebuild front and back this year costing about £550
- Side stand already replaced with fireblade stand
- Suspension bearings done
- Akra titanium system second hand fitted at about £650
- New reg/stator
- New camchain tensioners
- Tune up @ £500 whatever that entailed
- Brakes rebuilt
Overall pretty good and some bits to sort out but very happy.
I paid £3500 for this bike which is pretty good I think.
Good points...
- New reg/stator
- Brakes rebuilt
Ben17484
- Has thanked: 11 times
- Been thanked: 64 times
- Contact:
Re: Project Aprilia
That’s a nice looking bike!dern wrote: Sat Nov 05, 2022 10:44 am Picked it up this morning...
Good points...
- New reg/stator
- Brakes rebuilt
Good find
- Has thanked: 2556 times
- Been thanked: 4167 times
Re: Project Aprilia
That's a brilliant deal - but you already know that. All the important stuff has been done and most of the 'nice to haves' as well. The only potential worry is the bubbling tank. I know that a few Falcos (which use a tank of the same material) have had issued with bubbling which turned out to be terminal ethanol damage. Hopefully yours has been caught in time. If it were my bike the only fuel I'd put in would be Esso Super Unleaded - in most parts of the country it's E0 (pure dino-juice) even though it's marked on the pump as E5.
- MingtheMerciless
- Has thanked: 3644 times
- Been thanked: 2502 times
Re: Project Aprilia
What a cracking looking motorcycle.
Re: Project Aprilia
From that list it's been well looked after. Cheap fun and top bombing.
singlesman
- Has thanked: 227 times
- Been thanked: 144 times
Re: Project Aprilia
That looks lovely Mark, always wanted one so let me know if you decide to move it on!
My only concern with them was possible noise issues for track use, so would be interested to to know what it db’s it puts out if you ever get a chance to test it.
My iPhone noise app is spot on with no limits testing.
Cheers, Paul.
Cheers, Paul.
- Has thanked: 2849 times
- Been thanked: 1609 times
Re: Project Aprilia
Friend of mine ran one as his track bike for many years with Akra's - never had an issue with noise testing on any UK or Euro TD.singlesman wrote: Sat Nov 05, 2022 3:44 pm My only concern with them was possible noise issues for track use, so would be interested to to know what it db’s it puts out if you ever get a chance to test it.
Akra's aren't as loud as you think, I had Tigcraft's on mine and they blew 105dB without baffles.
- dern
Re: Project Aprilia
It’s meaty but not massively loud. I won’t be taking it on track though, as long as I get on with it it’ll be my road bike to replace the superduke.
Had a quick run on a private track and love it. It is pissing it down and there are leaves everywhere but it feels like a great riding position given I didn’t get it over 30.
Re: Project Aprilia
That is lovely. All the best with it @dern
Sometimes I think about a cheeky second bike for a project and then realise that I've never done any work on motorbikes and it would probably end up gathering dust in the corner of the garage.
Yamaha Tracer 9GT
- dern
Re: Project Aprilia
Slippery path, I'm up to eight bikes now.tricol wrote: Tue Nov 08, 2022 9:59 am Sometimes I think about a cheeky second bike for a project and then realise that I've never done any work on motorbikes and it would probably end up gathering dust in the corner of the garage.
- Has thanked: 5954 times
- Been thanked: 3572 times
Re: Project Aprilia
I still need to sort the track R6 in the garage. I'm just bloody useless at spanners. Happy to crack on with it but would rather have a responsible adult with me to guide me or someone equally as clueless as me to bounce ideas off as I follow the Haynes manual. TBF I can't make the bike worse! and it only needs re-assembly.
Re: Project Aprilia
I'd be in a dither of indecision. I'd not know where to begin,so I probably wouldn't.dern wrote: Tue Nov 08, 2022 10:20 amSlippery path, I'm up to eight bikes now.tricol wrote: Tue Nov 08, 2022 9:59 am Sometimes I think about a cheeky second bike for a project and then realise that I've never done any work on motorbikes and it would probably end up gathering dust in the corner of the garage.
- dern
Re: Project Aprilia
The one that needs the decisions and work is the zxr750... I just need to make up my mind which way to go and get on with it.
- dern
Re: Project Aprilia
Had the wind put up me a bit yesterday when I thought I'd found that the swing arm recall I'd only just found out about hadn't been done. Pulled the bike out to load it up in the van for its mot and double checked while I had more space and it has the new design on it so, like, phew.
Put a new battery in it that's a bigger capacity job and it just fits with some encouragement so when I have more time I'll do a better job of wedging it in with the seat.
Found that the tacho cover that I though was scratched is actually cracked and can't be replaced. Quite annoying but not the end of the world. Wondering whether some super glue would be it look the cracks invisible or very very visible... not sure.
Going to have to wait until December to insure it. With no NCB it's quite a lot to insure but I have 18 years on my DRZ (fuck knows why it's on that one, timing I guess) so when that expires I'll use that NCB against the Aprilia and the DRZ will cost me about a tenner more to insure with no NCB and most of the cost is made up of arrangement fees and the rest of the shit actually on top of the cost of the policy.
