Project Aprilia
Has thanked: 1926 times
Been thanked: 1728 times
Re: Project Aprilia
dern wrote: Mon Oct 31, 2022 9:15 pm
Mr Moofo wrote: Mon Oct 31, 2022 8:06 pm Didn't factory spec have gold frames ?
Or was that just the Tuono?
Some but not all.
Great that you got a black one! I always thought the gold was an acquired taste.
Re: Project Aprilia
I like.
Have you been able to verify the milage?
Some of them had an issue where the ODO reset when the battery was disconnected. Not just the trip counter, but the actual odometer.
Has thanked: 1183 times
Been thanked: 2277 times
Re: Project Aprilia
The odo reads 10k but according to the mot history it reset at 2k so 12k in all based on that info.
Has thanked: 2556 times
Been thanked: 4167 times
Re: Project Aprilia
I seem to recall that early Gen 2 RSVs had a swingarm recall and there were some instances of the suspension triangles fracturing if bearings weren't greased at stipulated intervals. This is not Gospel and just what I've heard on the 'Priller grapevine. I'd suggest giving Griff a call at AP Workshops in Tamworth for full chapter and verse.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Re: Project Aprilia
Post by A_morti »
mangocrazy wrote: Mon Oct 31, 2022 11:37 pm I seem to recall that early Gen 2 RSVs had a swingarm recall and there were some instances of the suspension triangles fracturing if bearings weren't greased at stipulated intervals. This is not Gospel and just what I've heard on the 'Priller grapevine. I'd suggest giving Griff a call at AP Workshops in Tamworth for full chapter and verse.
Happened to someone I know on a Tuono, in the arse end of nowhere.
Since this is a project bike, definitely a good place to start your preventative maintenance :)
Has thanked: 2849 times
Been thanked: 1609 times
Re: Project Aprilia
Add non-working rear brakes, crap clutch slave cylinders, out of balance throttle bodies, sprag clutches etc etc.
Still great bikes though - probably the only bike I've ever owned that I still regret selling.
Re: Project Aprilia
For repairs and advice, Griff Wooley or I used to use Don at Southern Cross in Kilburn - both know their potatoes.....
Has thanked: 5954 times
Been thanked: 3572 times
Re: Project Aprilia
That's one of my favourite looking sportsbikes ever, good work. Remember seeing one when they first came out in Colin Collins in Harrow and it looked bloody amazing.
I've been put off by the riding position (I is well oldz init) and the resetting clocks issues as never feel I can trust what's listed. However if you can get past that it's a great way to get a 999/SP1 rival for a fraction of the price mainly.
Re: Project Aprilia
I've no where to put it, I really need to get rid of one of the other bikes or have a major clean out, the weather looks shit for the foreseeable and I've got no no claims to put against it.
Can't bloody wait :)
Will be a long week.
Re: Project Aprilia
Supermofo wrote: Tue Nov 01, 2022 9:56 am That's one of my favourite looking sportsbikes ever, good work. Remember seeing one when they first came out in Colin Collins in Harrow and it looked bloody amazing.
I did think about the riding position vs a naked bike as I is also getting somewhat older, starting to get arthritis in my hands and generally less flexible but I've always wanted one and I'm not going to get any younger so fuck it.
Re: Project Aprilia
v8-powered wrote: Tue Nov 01, 2022 8:55 am Add non-working rear brakes,
caused by the bleed nipple being at the lowest point of the rear brake circuit...
v8-powered wrote: Tue Nov 01, 2022 8:55 am crap clutch slave cylinders,
Oberon seem to be one of the best alternatives - avoid Factory Pro
v8-powered wrote: Tue Nov 01, 2022 8:55 am out of balance throttle bodies,
In fairness, that can be an issue on any V-twin
v8-powered wrote: Tue Nov 01, 2022 8:55 am sprag clutches etc etc.
Never try to start the bike with a below-par battery; a quick way to kill the sprag
v8-powered wrote: Tue Nov 01, 2022 8:55 am Still great bikes though - probably the only bike I've ever owned that I still regret selling.
In spite of all the above, it's still a cracking bike and looks to be a real steal.
Re: Project Aprilia
It's apparently just had the stator circuit overhauled but I know these fail regularly but I'll see how that works out with the limited number of miles I do. If it turns in to a forever bike I'll replace the whole generator system from the later bike which solves the issue. It's just over 1k worth of bits but this is still way way cheaper than buying a new bike.
The bike will be on a smart charger all the time so I can look after the battery and sprag. The full sprag kit is a couple of hundred so won't break the bank.
I can balance the throttle bodies no problems.
I had an oberon on one of the ktms and will fit one if there are any issues.
The rear brake master can be angled to help with the problem or mounted vertically on a set of rear sets which feels like the way to go.
Re: Project Aprilia
I'm not sure if the RSV layout is the same as the Falco, but this is how I bled my rear Falco caliper. It needs a length of metal tube of the right i.d. and a long bolt, but does the job.
Has thanked: 20859 times
Been thanked: 13679 times
Re: Project Aprilia
Slightly worrying is, they sold it a couple of weeks back for a grand more, then relisted it as a quick, trade sale? Might be worth asking why the sale fell through?
Re: Project Aprilia
I spoke to the seller and the previous buyer messed about and the seller wants to get out of the business, this is his last bike and he wanted a quick sale where someone turns up with a van and takes it as is. Googling the company reveals that they starting a lock company and the seller confirmed that.
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Re: Project Aprilia
Post by Tricky »
dern wrote: Tue Nov 01, 2022 10:15 am I've no where to put it, I really need to get rid of one of the other bikes or have a major clean out, the weather looks shit for the foreseeable and I've got no no claims to put against it.
:thumbup: Nice- I like 8-)
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Re: Project Aprilia
Post by Bigyin »
mangocrazy wrote: Tue Nov 01, 2022 11:17 am I'm not sure if the RSV layout is the same as the Falco, but this is how I bled my rear Falco caliper. It needs a length of metal tube of the right i.d. and a long bolt, but does the job.
I think thats the common solution for bleeding the rear brake on the Multistrada as well. They dont work well for long as the reservoir is next to the catalytic converter so the heat from it boils the fluid. The common fix is constant bleeding and flushing the fluid or the proper fix is to use high temp brake fluid at about 75 quid a small bottle .....most people remove it, turn the caliper upside down and place it high to bleed it ;)
Re: Project Aprilia
Started to tidy up the garage to get the aprilia in. In the current state I can’t get all the bikes that were in there in. I’m sure it’ll be ok in the end.
Re: Project Aprilia
dern wrote: Fri Nov 04, 2022 4:29 pm Started to tidy up the garage to get the aprilia in. In the current state I can’t get all the bikes that were in there in. I’m sure it’ll be ok in the end.
Fair play to you,I couldn't contemplate working on a bike in there! Sets all my bells ringing. :(
Re: Project Aprilia
No choice. Houses are expensive. It’ll be fine :)
