Muc Off
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
Muc Off
Post by GuzziPaul »
Went out on the Le Mans today as the roads where mostly dry with a few puddles. When I got home the front of the engine and swinginarm was covered in road spray so I thought I'd give it a quick clean. Sprayed some Muc off on the engine and generally around the bike before washing with car shampo then rinsing off.
Noticed the aluminimum around the top of the engine and the valve covers were looking a bit "furry" has anyone else had this with Muc off? I've got some SDoc 100 but that's for "special occasions" only and Ive just bought 5 ltrs of Muc off.
I've wipped it over with Acf50 which has got rid of it.
Re: Muc Off
I've had a few issues with a few similar products but usually on engines when done before it cooled.
I've seen issues on cycling forums with Muc Off though yes
Re: Muc Off
I used it once but found it way too harsh! It furred up my polished alloy race can on my CCM. It appears to be a caustic as truck wash!
Has thanked: 5954 times
Been thanked: 3572 times
Re: Muc Off
I use this stuff that OCD recommend from the other place. Mixes with water and usually use 1/4 cleaner to water so it goes a fair way, much cheaper that way than SDOC. I'd say SDOC is better, but not enough to justify the extra. I went in halfs with my neighbour and got 5 litres for £35 from Amazon. That's not far off what you'd pay for 2 litres of SDOC and that's before you water it down.
https://gtechniq.com/products/auto/perf ... se-cleaner
Been thanked: 3504 times
Re: Muc Off
I've been used this stuff for ages, works well and dilutes 10:1
https://www.ebay.co.uk/itm/163645006505
Tarmacsurfer
Has thanked: 100 times
Been thanked: 111 times
Re: Muc Off
Post by Tarmacsurfer »
I've had the same issue with that stuff. It's very alkaline so if you leave it for more than a couple of mins on chrome or ally then it tends to discolour.
Re: Muc Off
I don't like Muc Off for some of the reasons already stated.
S-doc for me,though the stuff is a silly price.
Re: Muc Off
No probs here. I only wash road bikes the day before I sell them. And the enduro bikes when the dirt slows them down.
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Re: Muc Off
Post by Tricky »
I picked some of this up on a Sunday once when I was in Screwfix, and ever since haven't bothered with Sdoc or gunk etc-have never been a fan of Muc-off.
I use this in a squirty bottle and works a treat- dirt ( ;) ) cheap too 👍
1913
Has thanked: 18 times
Been thanked: 41 times
Re: Muc Off
Post by 1913 »
I used Muc Off and found similar issues.
I then watered it down and now find it works brilliantly. (fnur).
Been thanked: 2727 times
Re: Muc Off
1913 wrote: Sat Mar 28, 2020 8:26 pm I used Muc Off and found similar issues.
How much do you water it down? Even a vague guesstimated ratio would be helpful.
1913
Re: Muc Off
Post by 1913 »
cheb wrote: Sun Mar 29, 2020 9:14 am
Approximately from experimentation.
90% water, ok but does not move many of the stains.
50% water, much better and does not leave stains.
I use my baby Bosch Jet Washer now and I suspect it a higher proportion but due to the ability to cover it uses a bit less than hand spraying.
GuzziPaul
Re: Muc Off
Post by GuzziPaul »
Thanks for that, as I've just bought 5lts as I said at the start, watering down 50% should last me for ever.
