And improve the steering tooJody wrote: Tue Jul 12, 2022 5:51 pmProbably wanted to do wheelies !Skub wrote: Tue Jul 12, 2022 5:46 pmI wonder why.KungFooBob wrote: Tue Jul 12, 2022 5:18 pm Conversion to chain drive by bolting the final drive directly to the gearbox and adding a sprocket.
Weight saving?
Better handling?
Lighter?
Maybe just because he could.
- Has thanked: 7635 times
- Been thanked: 5937 times
- Has thanked: 10971 times
- Been thanked: 4003 times
Not sure about that tbh... Yes there's less rotating mass, but that would only work to reduce the "shaft effect" if it's assumed that ALL the rotating masses (crankshaft, gearbox shafts, final drive shaft) have not been designed to balance each others rotational effects.
But it's been known for decades - at least since Visordown days - that (as well as wheelies) shaft drive bikes simply can't be counter-steered.Rockburner wrote: Tue Jul 12, 2022 8:37 pmNot sure about that tbh... Yes there's less rotating mass, but that would only work to reduce the "shaft effect" if it's assumed that ALL the rotating masses (crankshaft, gearbox shafts, final drive shaft) have not been designed to balance each others rotational effects.
Thought you'd remember that
They have to be contra-steered, everyone knows that!Horse wrote: Tue Jul 12, 2022 8:51 pmBut it's been known for decades - at least since Visordown days - that (as well as wheelies) shaft drive bikes simply can't be counter-steered.Rockburner wrote: Tue Jul 12, 2022 8:37 pmNot sure about that tbh... Yes there's less rotating mass, but that would only work to reduce the "shaft effect" if it's assumed that ALL the rotating masses (crankshaft, gearbox shafts, final drive shaft) have not been designed to balance each others rotational effects.
Thought you'd remember that![]()
- Has thanked: 245 times
- Been thanked: 1228 times
- Contact:
- Cousin Jack
- Has thanked: 3016 times
- Been thanked: 2528 times
Interesting exhaust layout too.
Engineering reason? Or just 'cos it looked 'cool'?
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Maybe he just missed getting the spanners out to adjust the chain tension.
Looks like the swing arm pivot lines up pretty close to the sprocket too...
- Contact:
Looks like the forks NEED to be kicked out, to clear the headers!Cousin Jack wrote: Wed Jul 13, 2022 9:38 am Interesting exhaust layout too.
- Contact:
Lutin
- Has thanked: 369 times
- Been thanked: 383 times
I hope that you're comfortable with that.
- Has thanked: 2318 times
- Been thanked: 1824 times
Another new one to me spotted while out and about today
I have heard of Fantic, i think they mainly did motocross or trials stuff back when granny was a little boy. I would not be surprised if they are now Chinese owned and made. If it's good enough for AJS etc ...
- Been thanked: 9504 times
There's a semi-adventure version of the Caballero, I'll see if I can find a pic.
EDIT:
EDIT:
Apart from the paint the only real difference I can spot is a rack, but it's a whole different model
The one I saw was a 125, I can't make out the sticker on the rad scoop on your pic, is it maybe a 200! ?
I didn't mind the look of the one I saw but I felt 125 wouldn't be enough and as a 125 it had zero need of twin exhausts !
- Has thanked: 12619 times
- Been thanked: 8541 times
It's the 500 I think.Jody wrote: Wed Jul 13, 2022 2:33 pm The one I saw was a 125, I can't make out the sticker on the rad scoop on your pic, is it maybe a 200! ?
- Has thanked: 2852 times
- Been thanked: 1611 times
- Has thanked: 4088 times
- Been thanked: 2513 times
Fantic made Italian mopeds back in the 70's https://classic-motorbikes.net/fantic-c ... road-test/Jody wrote: Wed Jul 13, 2022 2:24 pm Another new one to me spotted while out and about today
.In recent years they' were Italian designed but Chinese manufactured.Not sure if it's Fantic but one of the Italian firms were building their current bikes back in Italy once again.Those Caballero's look half decent.
How can we not remind ourselves of the famous Fantic Chopper?
