S1000RR Sport 2022
wull
Has thanked: 979 times
Been thanked: 1858 times
Re: S1000RR Sport 2022
Post by wull »
I won’t be using that mount again. I’m using my ram mount which is secured to the top yoke and you can clearly see the vibration and buzz that you get at 8k rpm. The S1000rr’s are renowned for it which you feel badly through the bars which you can solve from a riders point of view by fitting heavier bar ends, sadly it doesn’t solve the issue with mounting the camera via the top yoke.
Has thanked: 5969 times
Been thanked: 3573 times
I'm sorry officer I was having to do a 100mph, you should see the vibration on the go pro at 8k rpm :angry-cussingblack: It's an outrage :lol:
Been thanked: 15507 times
That rpm counter moves quickly!!!
Bit weird that it goes 0-4-8-9-10 etc. I suppose that's a race pro 3 thing, ISTR it looking more conventional in previous vids.
wull
Post by wull »
Mr. Dazzle wrote: Fri Jul 15, 2022 4:58 pm Bit weird that it goes 0-4-8-9-10 etc. I suppose that's a race pro 3 thing, ISTR it looking more conventional in previous vids.
No it’s part of the sport dash, you can select it regardless of what riding mode you are in, I’ll do a quick video showing this.
wull
Post by wull »
Every time you switch the bike on it goes to what they call the pure riding screen, this is the default setting. From there you press down on the menu and then select sport and then when in there you have 3 screens to choose from. You press the multifunction switch to the right to select the other displays and left to go back and then up on menu to come out of there to go back to the pure screen.
When you go into sport when you select the second screen you have the lap timer function, once you’ve started the lap timer you can go back to the pure screen and even though the timer is no longer displayed it will still record laps etc, you just don’t see it and need to go back into that display to see it, quite good if you don’t want to be preoccupied with your lap times.
Has thanked: 2858 times
Been thanked: 3517 times
Jeez... sounds like your in a train carriage, like in the cowboy films. El paso next stop. 🙂
wull
Post by wull »
Dodgy knees wrote: Fri Jul 15, 2022 6:40 pm Jeez... sounds like your in a train carriage, like in the cowboy films. El paso next stop. 🙂
That’s the gazebo getting blown about
wull
Post by wull »
Bigjawa
Has thanked: 225 times
Been thanked: 971 times
Post by Bigjawa »
wull wrote: Fri Jul 15, 2022 2:10 pm I won’t be using that mount again. I’m using my ram mount which is secured to the top yoke and you can clearly see the vibration and buzz that you get at 8k rpm. The S1000rr’s are renowned for it which you feel badly through the bars which you can solve from a riders point of view by fitting heavier bar ends, sadly it doesn’t solve the issue with mounting the camera via the top yoke.
What's the wee amber triangle that flashes up the odd time?
Bigjawa wrote: Sat Jul 16, 2022 3:12 pm What's the wee amber triangle that flashes up the odd time?
That's Wull's missus paging him to get the fuck home already. :thumbup:
wull
Post by wull »
Skub wrote: Sat Jul 16, 2022 3:29 pm
wull
Post by wull »
That’s the traction control light flashing. You’ll see to the left side of the display there is the DTC torque reduction graph, that’s the intervention and how much it cuts power in %, sometimes that lights up but not enough to cause the traction lift to flash.
Has thanked: 7630 times
Been thanked: 5936 times
It's the "you're having too much fun" light :D
Bigjawa
Post by Bigjawa »
wull wrote: Sat Jul 16, 2022 4:21 pm That’s the traction control light flashing. You’ll see to the left side of the display there is the DTC torque reduction graph, that’s the intervention and how much it cuts power in %, sometimes that lights up but not enough to cause the traction lift to flash.
When you think about it, a bike that'll want to spin up at over 100 on a dry road, with some of the best suspension money can buy, is absolutely bloody awesome.
Amazing bit of machinery.👍👍👍
So at 100mph, accelerating, and losing grip, someone things you might want to be studying that sort of information? :?
Nordboy
Has thanked: 580 times
Been thanked: 830 times
Post by Nordboy »
KungFooBob wrote: Fri Jul 01, 2022 9:29 am Keys.
Bit old fashioned.
My Beemer is keyless, don't they do it as an option on the sports bikes?
So is my C400GT scooter ;)
In fact, the screen and TFT connection etc is better, more functions on my scooter than my 1250RS I have in work!! It's just a smaller engine, smaller wheels, crapper suspension........ :lol:
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
Horse wrote: Sun Jul 17, 2022 8:06 am
If you cant multi-task, dont get one. 8-)
Does it have any sort of datalogging?
wull
Post by wull »
Mr. Dazzle wrote: Sun Jul 17, 2022 9:16 am Does it have any sort of datalogging?
When using the lap timer it’ll give you x amount of information for each lap, this can only be used in Ride Mode Pro. In the other modes when connected to the phone you can get similar information through the phone app.
I however have the BMW gps lap trigger and 2D data logger fitted which gives you the full shebang, it also means the lap timer works via gps meaning you don’t have to manually trigger it every lap via the flasher.
